How to initialize arcgis python library
1874
01-11-2021 01:08 AM
tino415
I'm triing python arcgis sdk and I did:
```bash
pip install arcgis
And then
```python
from arcgis.gis import GIS
from arcgis.features import GeoAccessor, GeoSeriesAccessor
And I get
File "/usr/local/lib/python3.5/site-packages/IPython/core/interactiveshell.py", line 3325, in run_code
exec(code_obj, self.user_global_ns, self.user_ns)
File "<ipython-input-4-876ff2e6ffd8>", line 2, in <module>
File "/usr/local/lib/python3.5/site-packages/arcgis/__init__.py", line 3, in <module>
from . import (features, geoanalytics, geocoding, geometry,
File "/usr/local/lib/python3.5/site-packages/arcgis/features/__init__.py", line 22, in <module>
from .layer import FeatureLayer, Table, FeatureLayerCollection
File "/usr/local/lib/python3.5/site-packages/arcgis/features/layer.py", line 254
attachment_path = os.path.join(path, f'{md5_hash}.jpg')
SyntaxError: invalid syntax
What is going on?
Tags (1)
DanPatterson
MVP Esteemed Contributor
DanPatterson
You probably don't have the correct relase number if you are using python 3.5 since the most current uses python 3.6.x  See the instructions for creating and environment and installing using conda
ArcGIS API For Python | ArcGIS for Developers
... sort of retired...
tino415
Thank you for your answer,
mentioned tutorial is using arcgis pro I'm not sure if it is same thing as the thing I have in jp notebooks in arcgis online,
secondli when I check pip package I installed on https://pypi.org/project/arcgis/ it list 3.5 as supported python version and esri is there mentioned as mantainer, should I consider this package as something outdated and no longer supported or unofficial? If it is unofficial, is there place where I can report a issue?
Sadly, task I'm working have limited resources, I think it is not feasible to update python or change package manager (I noticed tutorial is using conda)
I managed to achieve what I wan't using nodejs sdk since it is also used in target environment...
tino415
*If it is unofficialofficial, is there place where I can report a issue?
DanPatterson
The github site is the best place to report issues
Esri/arcgis-python-api: Documentation and samples for ArcGIS API for Python (github.com)
