How to export a referenced feature layer w/ topology
512
12-08-2025 09:29 AM
Labels (2)
JBeasley
Hello, using the ArcGIS API for Python, I would like to create a FGDB export of the Default view of a feature service with a topology within Portal, which could then be downloaded if needed. This exported FGDB item will act as a backup before running an update process.
I have ensured feature access and export are enabled.
Because this is a backup, I am only interested in either creating a deep copy (no luck there either using clone_items, I get an error that it finds a NoneType pbject- I assume the topology?) or creating this FGDB, so the topology can be maintained. I am avoiding using ArcPy due to performance. We can do SQL backups, but I wanted an accessible backup so I could rollback the service if needed.
Would appreciate having what is and isn't possible clearly laid out, and what my options may be. Thank you.
