how to create advanced view with arcgis api for python
2017
06-06-2024 08:24 AM
MatthieuANDRE3
Hello everyone,
I've had a problem for several days that I can't solve. I want to create an advanced view from 2 hosted views.
Let me explain:
I have a hosted feature layer for which I'm creating a view (I'm only interested in certain fields). No problem to create this view.
I have a hosted table for which I'm creating a view (I'm only interested in certain fields). No problem to create this view.
 For each of these views I use the manager.create_view method
My problem is that I can't create a new view from the 2 previous views, whereas I can do it perfectly well from the graphical interface of map viewer classic.
The join_features method doesn't seem to be what I'm looking for because it creates a new independent hosted feature layer (which I don't want).
So I used the method gis.content.create_service(name='xxx', service_type='featureService', is_view=True)
It seems to work, but I still have to update the layer definition using the fl.manager.update_definition(definition) method to modify the [layers] tag in the properties, and that's where I run into my problem, because I don't know how to make sure my json is properly parameterized.
If you have an idea, I'd love to hear from you.
many thanks in advance.
Translated with DeepL.com (free version)
EarlMedina
EarlMedina
MatthieuANDRE3
unfortunately I get the following error message when calling the add_to_definition method.
Exception                                 Traceback (most recent call last)
/tmp/ipykernel_51/2098146221.py in <cell line: 120>()
    118 }
    119
--> 120 view_flc.manager.add_to_definition(definition_to_add)
/opt/conda/lib/python3.9/site-packages/arcgis/features/managers.py in add_to_definition(self, json_dict, future)
   2546         }
   2547         adddefn_url = self._url + "/addToDefinition"
-> 2548         res = self._con.post(adddefn_url, params)
   2549         if future and "statusURL" in res:
   2550             executor = _cf.ThreadPoolExecutor(1)
/opt/conda/lib/python3.9/site-packages/arcgis/gis/_impl/_con/_connection.py in post(self, path, params, files, **kwargs)
   1522         if return_raw_response:
   1523             return resp
-> 1524         return self._handle_response(   1525             resp=resp,
   1526             out_path=out_path,
/opt/conda/lib/python3.9/site-packages/arcgis/gis/_impl/_con/_connection.py in _handle_response(self, resp, file_name, out_path, try_json, force_bytes, ignore_error_key)
    998                     return data
    999                 errorcode = data["error"]["code"] if "code" in data["error"] else 0
-> 1000                 self._handle_json_error(data["error"], errorcode)
   1001             return data
   1002         else:
/opt/conda/lib/python3.9/site-packages/arcgis/gis/_impl/_con/_connection.py in _handle_json_error(self, error, errorcode)
   1021
   1022         errormessage = errormessage + "\n(Error Code: " + str(errorcode) + ")"
-> 1023         raise Exception(errormessage)
   1024
   1025     def post_multipart(
Exception: Unable to add feature service definition.
Invalid argument. Source service infos_UD_v2 does not exist.
(Error Code: 400)
what's strange is that the infos_UD_v2 table does exist
MatthieuANDRE3
it works, I had to adapt some things I hadn't thought of.
many thanks
