How to change the height of the map widget (arcgis Python api) in Jupyter Notebook?
2462
11-30-2019 11:21 AM
ChangjieChen
New Contributor II
MatthiasSchenker
Hi Changjie
You should be able to change this via the layout property, here an example:
from ipywidgets import *
map.layout=Layout(flex='1 1', padding='100px', height='300px')
Best,
Matthias
DanPatterson_Retired
I don't suppose it would be the Extent property of widget or the sdf
arcgis.widgets module — arcgis 1.7.0 documentation
ChangjieChen
New Contributor II
I think the extent property controls the lat-lon of the map itself. Not the size of the plot.
MatthiasSchenker
Hi Changjie
Best,
Matthias
Per_Åke_MattiasWallin
New Contributor III
Thank you Matthias!  I cannot believe I haven't seen this before.
ChangjieChen
New Contributor II
Matthias, thank you for your answer. Searching for a solution within the arcgis API exhausted me. Never thought about this direction you pointed. I really appreciate it.
