gis.content.search() parameter substitution
10682
14
08-09-2018 09:09 AM
RobertHolliday
Greetings,
I am using the ArcGIS API for Python and I am struggling with passing parameters to the gis.content.search function.
  1. If I type in command parameters  and run the snippet temp_list  =  gis.content.search(query="Boundaries AND owner:MontanaStateLibrary) a list of content is returned.
  2. However if I build a string, st = 'query=' + '"' + 'Boundaries AND owner:MontanaStateLibrary' + '"',  and do something like this: temp_list  =  gis.content.search(st) an empty list is returned.
    1. In troubleshooting I have copied the printed string, st,  from the interactive window and pasted the text into the gis.content.search()  command which results in a list of content.
  3. As of right now the following code is just a brain dump.  I am using 2 lists to build the parameter string.
    try:
    query_list = ['Boundaries', 'ConservationEasements', 'Geographic Names', 'Hydrography', 'LandCover', 'Mapping Control', 'MontanaMask', 'Montana Managed Areas', 'Montana NAIP', 'NAIP', 'Parcel', 'PLSSS', 'PublicLands', 'Roads', 'Structures', 'Watershed', 'Wetlands']
    item_type_list = list()
    st = 'item_type =' + '"' + 'Feature Layer' + '"'
    item_type_list.append(st)
    st = 'item_type =' + '"' + 'Imagery Layer'# + '"'
    st = 'item_type =' + '"' + 'Map Image Layer'# + '"'
    for q in query_list:
    st = 'query=' + '"' + q + ' AND owner:MontanaStateLibrary' + '"' #+ ', '
Am I missing something obvious?
arcgis-api-python‌
JoshuaBixby
MVP Esteemed Contributor
Did you trip my code changes?  Do they work?
RobertHolliday
Sorry I did try what you suggested after taking a second closer look at what you suggested.
Screen Capture
JoshuaBixby
I see what Dan is getting at above, what about:
st = q + ' AND owner:MontanaStateLibrary'
temp_list = gis.content.search(query=st)
RobertHolliday
Success!  I am not sure I would have ever figured out to enter an unquoted string.  Thanks to both Joshua Bixby and Dan Patterson for the help.
Screen Capture
RobertHolliday
Thanks to you both for the help.
Bob Holliday
Montana State Library
[email protected]<mailto:[email protected]>
