Geoaccessor.from_df
6461
01-11-2022 02:43 PM
PenelopeMitchell2
Hello,
I am trying to convert a pandas dataframe that contains geometry (started from a feature class) to a spatially enabled dataframe using the GeoAccessor.from_df() function. See code snippet below:
sdf = GeoAccessor.from_df(CompDF, sr = 'OBJECTID', geometry_column='SHAPE')
sdf.spatial.plot()
referencing data as shown below for example:
OBJECTIDSHAPE
0{'x': 1587057.9938000003, 'y': 808409.8682000004, 'spatialReference': {'wkid': 32616, 'latestWkid': 32616}}
But I get a ValueError: Expected object or value
The data types are: OBJECTID is int64, SHAPE is object. I imagine the SHAPE dtype is throwing the error- if so, how do I get the SHAPE dtype to 'Geometry'?
Or what is a good strategy to converting a dataframe with geometry information to a feature class or shapefile? I used to use GeoPandas but since I've upgraded my Pro version (2.8.2) the GeoPandas patch doesn't work in Pro due to compatibility issues.
Thanks for any insights.
DanPatterson
MVP Esteemed Contributor
Just a wild guess, and not wanting to look up the help just yet, and based on esri's use of "sr", I suspect that that is the reference to the spatial reference and not OBJECTID
arcgis.features module — arcgis 1.9.1 documentation
sr
Optional integer. The WKID of the spatial reference.
(I had to check... just in case)
... sort of retired...
jcarlson
Is there some reason that you can't just use GeoAccessor.from_featureclass and leapfrog the non-spatial dataframe?
Using from_df is specifically for dataframes with an address string in them, and the resulting spatial dataframe will have the geocoded points.
Since your data looks like it's points, there are a couple ways you can do it. The first, and easiest, is to use set_geometry. You could even set the inplace parameter to "True" and turn your non-spatial dataframe into a spatial dataframe if you wanted.
sdf = CompDF.spatial.set_geometry('SHAPE', 32616)
The second method is more hacky, but I recall at least one or two situations where I had to go about it this way for some reason. Essentially, you take the 'SHAPE' column and split it up into multiple columns, then use from_xy to create the spatial dataframe.
xy_df = pd.concat([CompDF, CompDF['SHAPE'].apply(pd.Series)], axis=1)
sdf = GeoAccessor.from_xy(xy_df, 'x', 'y', 32616)
- Josh Carlson
Kendall County GIS
PenelopeMitchell
Thanks for your response!
I tried the first approach but still got the same error.
I'll try the second method, but have to do some string manipulation on the x and y coord columns and just haven't had a chance to get to it yet. I'll update my post after i give it a go.
Thanks again,
Penelope
