FeatureLayer::query() - Force HTTP POST instead of GET?
1459
10-15-2025 11:08 AM
MobiusSnake
MVP Regular Contributor
Hi, I ran into an issue earlier where the query() call would result in what looked like a JSON decoding error.  This is code that I'd run many, many times before, so I dug into it and the cause was an unusually complex polygon being passed in as a filter.  I copied the filter's geometry into the REST API web interface and GET failed, while POST behaved as expected, seemingly due to the data limit with HTTP GET.
I built in a workaround for this specific script, but is there a way to force query() to use POST rather than GET in the future?  If not, is there an existing idea for this?  (I looked but couldn't find one.)
Clubdebambos
I had a similar error using complex polygons and union() and I vaguely recall that this was due to be fixed in 2.4.2. I can't remember where I read that, but more than likely on the Esri GitHub.
EDIT: found links
https://github.com/Esri/arcgis-python-api/issues/2345
https://github.com/Esri/arcgis-python-api/issues/2334
Further Edit:
My workaround, although I wasn't performing a similar workflow to yours, was to convert all geometry to Shapely geoms, use the Shapely functions for union/dissolve and convert back to ArcGIS API for Python type features.
~ learn.finaldraftmapping.com
Clubdebambos
EDIT: found links
Further Edit:
KenGalliher1
Adding to the response from @Clubdebambos : This was fixed to allow for long url strings to be properly decoded in a GET request. The fix can be found in the 2.4.1.3 patch and the latest 2.4.2 release.
