FeatureLayer Calculate SQL Syntax
1320
11-18-2021 12:33 PM
mapmcburney
Hello I have a Feature Layer with three integer fields (A, B, and C)
I want to calculate the percentage between A and B. The following will run but I only get values of 100 or 0. Nothing in between, and manual calculations prove that there are valid values between 100 and 0.
overlay_result_layer.calculate(where= "1=1",calc_expression={"field": "C", "sqlExpression":"(B/A)*100"})
Can anyone see what is wrong with my syntax?
For additional info, I run the calculation below right before without errors perfectly fine;
overlay_result_layer.calculate(where= "1=1",calc_expression={"field": "B", "sqlExpression": "D * 247.105"})
jcarlson
It's the integers. Take your first expression, (B/A) * 100. Since B/A evaluates first, you're stuck with whatever rounded integer value results from the division. That is, 0 or 1, which then multiplied by 100 gives you 0 and 100, respectively.
Try instead, (B*100)/A. By multiplying your integer first, you avoid truncating the divided value as drastically.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
mapmcburney
You are a legend! Thank you!
