Failed to create Web Map when cloning
1583
01-03-2023 02:31 AM
jorisfrenkel
I am experimenting with cloning content from ArcGIS Online to Portal. I used the samples from https://developers.arcgis.com/python/guide/cloning-content/#the-cloning-process
I succeeded cloning hosted feature layers, web maps and a web mapping application.
However I'm now running into an error when cloning web maps with this line of code (which I used succesfully before):
cloned_wm = target.content.clone_items(items=[testwm],owner="<portal admin username>")
The response is this:
_ItemCreateException                      Traceback (most recent call last)
In  [9]:
Line 1:     cloned_wm = target.content.clone_items(items=[testwm],owner="portaladmin")
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py, in clone_items:
Line 5090:  return deep_cloner.clone()
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\common\_clone.py, in clone:
Line 748:   results = executor.submit(self._clone, executor).result()
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\concurrent\futures\_base.py, in result:
Line 432:   return self.__get_result()
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\concurrent\futures\_base.py, in __get_result:
Line 384:   raise self._exception
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\concurrent\futures\thread.py, in run:
Line 56:    result = self.fn(*self.args, **self.kwargs)
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\common\_clone.py, in _clone:
Line 735:   raise ex
Line 2253:  raise _ItemCreateException("Failed to create {0} {1}: {2}".format(original_item['type'], original_item['title'], str(ex)), new_item)
_ItemCreateException: ('Failed to create Web Map <name of web map>: 4', None)
I am still trying to figure this out, but not getting anywhere so far. If you have any suggestions, please help!
jorisfrenkel
Got it already, the solution was so simple, but for the record I am posting it here.
The web map that I wanted to clone had an invalid layer. After removing that layer, the cloning process worked allright.
jorisfrenkel
