extract_data sample
2185
12-30-2018 01:33 AM
LucasLew
  • I have a Hosted Feature service that I own and also have the Extract capability enabled.
  • Contains two layers, of which I want to download the first layer into a file geodatabase
I was hoping to find a sample that uses arcgis.extract_data
This post is similar, but looks like the op ended up using ArcPy.
Have tried a few things:
from arcgis.gis import GIS
from arcgis.features.manage_data import extract_data
gis = GIS("https://mydevplan.maps.arcgis.com/","un","pw")
waze_hfs_item = gis.content.get('5c80a03f09154b2bb845f986dce325cd')
waze_alerts_layer = waze_hfs_item.layers[0]  # REST Endpoint for layer returned
# outputGDB = arcgis.extract_data(['Alerts'])        # Exception: Job failed.
# outputGDB = arcgis.extract_data(waze_hfs_item)     # Exception: Job failed.
outputGDB = arcgis.extract_data(waze_alerts_layer)   # TypeError: 'FeatureLayer' object is not iterable‍‍‍‍‍‍‍‍‍‍‍
I believe all I really need to supply to extract_data is :
input_layers :Required list of strings
Was wondering if someone could point me to a working sample that leverages extract_data.  I am sure this is a simple one.
LucasLew
outputFGDB = extract_data(waze_hfs_item.layers, output_name="Waze_Extract", data_format="FILEGEODATABASE")
outputFGDB.download('C:\\Workings\\waze_analysis')
The above works in downloading all of the layers from the hosted feature service to a shapefile.
  • I only want the first layer.  How can I achieve this?  waze_hfs_item.layers[0] throws an error.
  • Has anyone created a clean-up step to remove the new item from the portal after successfully downloading?
If I refer to the credits page:
What does not require service credits?
  • Exporting data stored in ArcGIS Online.
However, I can confirm that using extract_data does indeed use credits.  Is this a bug?
As we are doing this on a daily basis, using credits for exporting our data is not going to be feasible.  Was hoping to take the Extract path over using SYNC/CreateReplica.
SimonJackson
Using createreplica gets around the credits issue, but the service needs SYNC enabled (which has more overhead for publisher when compared to Extract).
replica = waze_flc.replicas.create(replica_name = 'Waze_Download',
                                   layers = '0',
                                   data_format = 'filegdb',
                                   out_path = './download')
