Exception: A general error occurred: 'token' - Closest facility analysis project
1710
03-22-2024 10:50 AM
kalpanaGelli
Hi everyone,
  i working on a project to perform network analysis ( finding closest facility, best route between multiple stops.) using arcGIS api for python in jupyter notebbok. i used all the required packages and modules. i finished most of the code work and got the results. But when i am running this code,
getting error like :
 I checked authentication credentials , account activity. everything is good. can you please help me to figure out  this one ? can you give your thought one it ?
David_McRitchie
Hey Kalpana would it be possible to see the full notebook for this?
It could be worth sharing your layers publicly and testing the notebook again. From the error message it seems to definitely be a problem with authenticating, likely with the Network layer, facilities or incidents layers.
For this the following technical blog from Esri Australia is worth consulting.
Hope that helps,
David
Esri UK -Technical Support Analyst
kalpanaGelli
Hi David,
   Thanks for your response on it.  I figured out and it was about API key.
I appreciate your response. Thank you.
