EXB .zip creates Draft, Not Published
1691
08-16-2024 08:22 AM
Labels (3)
CS_IBM
I used a  file = gis.content.add() example to add a EXB.zip to AGOL.
The script worked, but I needed to Publish the EXB App.
I am only getting a Draft now, not a Published EXB App.
I cannot work out why, any suggestions would be appreciated.
I cannot do Save or Publish??
The code is:
### Data
layers=r"C:\EXB\v3.zip"
### XEB.zip to AGOL
item_properties={"type": "Web Experience", "title": "v3",
"description": "v3 Layers", "tags": "v3 Layers",
data=layers,
When I add
file = WebExperience.publish()
I get an error:
AttributeError: type object 'WebExperience' has no attribute 'publish'
Tags (3)
JakeSkinner
Esri Esteemed Contributor
Hi @CS_IBM,
Try the following:
# Data
# XEB.zip to AGOL
            data=layers,
# Publish Experience Builder App
app_properties = {'typeKeywords': 'status: Published'}
file.update(item_properties=app_properties)
CS_IBM
Hi Jake,
Thanks for the advice, that Publishes, but the EXB is still empty.
Clive
JakeSkinner
Was the EXB app created with the EXB App Developer Edition?  I'm not an expert with EXB, but I'm not sure if you can create an app in the DEV edition, and publish to AGOL/Enterprise.
