Error when cloning Survey123 form
1179
01-08-2025 01:38 AM
HanliePetoors
I'm using the process outlined here to try and clone a survey from AGOL to an enterprise portal.
Everything works fine up until the line where I actually clone the items:
# Identify the folder associated with the survey
fldr = next((f for f in full_folder if f['id'] == survey_folder), 0)
#List all the items within that folder to be cloned later on
fldr_items = usr.items(folder=fldr)
# Create a new folder with the same name as the source folder to clone the contents to
target.content.create_folder(folder=fldr['title'])
# Clone items to the new folder
cloned_items = target.content.clone_items(items=fldr_items, folder=fldr['title'])
This gives me an error
_ItemCreateException: ('Failed to create Feature Service EIIF Monitoring Tool V6: {\'code\': 500, \'message\': "The submitted field \'creationdate\' is not available in the layer \'0\' of the service \'Hosted/service_3053a\'.", \'details\': []}', <Item title:"service_3053a" type:Feature Layer Collection owner:myusername>)
The source survey has a field called 'CreationDate' that Survey123 added itself. I don't know why the clone method is looking for a field called 'creationdate'.
Does someone know how to resolve this error?
Thanks
Hanlie
JeffGarcia
_ItemCreateException: ('Failed to create Form GIS Trainings: Failed to update Form GIS Trainings: Resource does not exist or is inaccessible.\n(Error Code: 404)', <Item title:"GIS Trainings" type:Form owner:userAdmin>)
Hi @HanliePetoors, were you ever able to figure this one out? I am seeing a very similar error trying to clone a survey form within my same portal environment. I am using notebook server (10.0 runtime with arcgis version 2.3.0) on enterprise version 11.3.
HanliePetoors
@JeffGarcia unfortunately not.
To be honest, I have never been able to get the clone_items method to work for anything. Just the other day I wanted to clone a feature service from one AGOL organisation to another and it failed once more.
Good luck
Hanlie
