Error trying to sync bulk published datastore item "Invalid value for serverFolder. Layers have been published from this data store before and the val
1043
11-26-2024 08:16 PM
DrewDowling
I'm trying to sync a bulk published datastore item following the sample code here.
Code I have tried
bulk_publish_job = portal_ds.publish_layers(item = db_dsitem,
                                            srv_config = service_template,
                                            server_id = host_id,
                                            folder = None,
                                            server_folder= None)
                                            server_id = host_id)
                                            server_folder= 'CurrentFolderName')
I get this error no matter the value I enter for the server folder.
Publish layers failed.
Invalid value for serverFolder. Layers have been published from this data store before and the value is read-only. Passing null is valid.
(Error Code: 400)
MatejVrtich
Try server_folder="", at least it worked for me.
MatejVrtich
DrewDowling
Thanks @MatejVrtich This is what worked for me as well.
