error in join field "name 'self' is not defined"
1231
03-17-2025 09:44 AM
Labels (3)
CecilaMalvezzi
I'm having an issue about "join feature" in geoanalytics server tool. I'm trying to build the tool in arcpy, but also playing in toolbox for testing.
In ArcGIS Pro, in toolbox, it's returning me that error:
File "C:\Program Files\ArcGIS\Pro\Resources\ArcToolBox\scripts\ga_server_joinfeatures.py", line 42, in <module>
params['context'] = set_context(arcpy.env.outputCoordinateSystem,
NameError: name 'self' is not defined
in jupyter, i'm coding like that:
arcpy.geoanalytics.JoinFeatures(
target_layer="https://#####/server/rest/services/Hosted/grid_project/FeatureServer/3",
join_layer="https://####/server/rest/services/Hosted/grid_street_intersect_sum_teste/FeatureServer/0",
output_name='"JoinFeature_grid"',
join_operation="JOIN_ONE_TO_ONE",
spatial_relationship="",
spatial_near_distance=None,
temporal_relationship="",
temporal_near_distance=None,
attribute_relationship="id_unico id_unico",
summary_fields=None,
join_condition="",
data_store="SPATIOTEMPORAL_DATA_STORE",
keep_all_target_features="KEEP_ALL",
include_distance=None,
distance_unit=""
And it also return to me "name 'self' is not defined".
Can someone help me with that?
DanPatterson
MVP Esteemed Contributor
Join Features (GeoAnalytics Desktop)—ArcGIS Pro | Documentation
from the code example, "layers" are required for the inputs, and the workspace was defined.
Is that your case? or is there more code?
... sort of retired...
DerekGourley
Hi CecilaMalvezzi,
Would you be able to share the version of Pro and Server that you are using?
Derek Gourley
GeoAnalytics Product Engineer
