ERROR 002901: Sharing related error during geo-processing (Unable to check if service exists. (SN)) Failed to execute (UploadServiceDefinition)
1172
04-28-2022 07:34 AM
MaxBöcke
Hi
we are working on an automation process which should publish multidimensional cloud raster files.
We tested with Notebooks in ArcGIS Pro 2.8 and ArcGIS Notebook Server 10.9.1. Both approaches produce the same error messages.
Here is the code:
from arcgis.gis import GIS
import arcpy
import json
import shutil
import arcgisscripting
import xarray as xr
from netCDF4 import Dataset as NetCDFFile
import numpy as np
gis = GIS("home")
output_draft = '/arcgis/home/temperature_interim2.sddraft'
service = "SN"
con = "/arcgis/home/hub_hereon_de_image.ags"
# arcpy.CreateImageSDDraft(out_rasterdataset, output_draft, service,
#                         'FROM_CONNECTION_FILE', con, True, None, "netCDF test", "netCDF,test")
                        'ARCGIS_SERVER')
try:
    arcpy.StageService_server(
        '/arcgis/home/temperature_interim2.sddraft', '/arcgis/home/temperature_interim3.sd')
    warnings = arcpy.GetMessages(1)
    print(warnings)
except Exception as stage_exception:
    print("Sddraft not staged. Analyzer errors encountered - {}".format(str(stage_exception)))
inSdFile = '/arcgis/home/temperature_interim3.sd'
arcpy.UploadServiceDefinition_server(inSdFile, con)
Error Message:
ExecuteError                              Traceback (most recent call last)
/tmp/ipykernel_482/388611030.py in <module>
      3 # inServer = '/arcgis/home/rasterimage.ags'
      4 # inServer=r"C:/Users/Chaudhr1/arcgis/rasterimage.ags"
----> 5 arcpy.UploadServiceDefinition_server(inSdFile, con)
/opt/conda/lib/python3.7/site-packages/arcpy/server.py in UploadServiceDefinition(in_sd_file, in_server, in_service_name, in_cluster, in_folder_type, in_folder, in_startupType, in_override, in_my_contents, in_public, in_organization, in_groups)
   1293         return retval
   1294     except Exception as e:
-> 1295         raise e
   1296
   1297
   1290     from arcpy.arcobjects.arcobjectconversion import convertArcObjectToPythonObject
   1291     try:
-> 1292         retval = convertArcObjectToPythonObject(gp.UploadServiceDefinition_server(*gp_fixargs((in_sd_file, in_server, in_service_name, in_cluster, in_folder_type, in_folder, in_startupType, in_override, in_my_contents, in_public, in_organization, in_groups), True)))
   1293         return retval
/opt/conda/lib/python3.7/site-packages/arcpy/geoprocessing/_base.py in <lambda>(*args)
    510         val = getattr(self._gp, attr)
    511         if callable(val):
--> 512             return lambda *args: val(*gp_fixargs(args, True))
    513         else:
    514             return convertArcObjectToPythonObject(val)
ExecuteError: ERROR 002901: Sharing related error during geo-processing (Unable to check if service exists. (temp_netCDFwv1))
Failed to execute (UploadServiceDefinition).
When we use a simple Map Image Service the process is working fine. Not with an Image layer.
It would be nice if someone could give us a hint?
Thx a lot.
Max
