Download Excel file as .zip file with Geoprocessing
3672
03-19-2019 09:48 AM
DEVAPP
I have an ArcGIS REST Service that shows me more different Table, all tables are stored into Oracle Geodatabase Enterprise. I have written a python script that calls the REST service, extract data and create an Excel file. The Excel is added into a zip file.
The zip file is written into the folder of the script.
I have created a toolbox on ArcCatalog and I have set a parameter (GetParameterAsText as input) for the script.
When I run the script by ArcCatalog, works fine and the zip file is added into the folder.
After published on ArcGIS Server the script as Geoprocessing, I have noticed that the zip file is not written into folder arcgisjobs/gp/geoprocessing_name/scratch.
There is some sample to see how I can download specific .zip folder created by the script on the server?
The zip file contains all table data formatted into Excel
Thanks
Best
GurminderBharani1
You can try the following steps:
The Output parameter first set it as derived in the script properties > parameters > parameter properties > type > derived.
Also, keep the direction > output
Then in the script write:
arcpy.SetParameter(1,open(r"E:\IMAGERY\CSX\planet_order_321693\OutputGurminder\out.txt", "w"))
I am saving text in my case, in your case you call the method to save the excel zip file instead of open(). Then you go ahead and publish as a geoprocessing service.
-Gurminder
