dissolve_boundaries() error - Connection reset by peer: socket write error
1702
01-03-2024 04:32 PM
NickNuebel
I trying to write a script that queries a feature layer, crosswalks some attributes, dissolves the crosswalked features, then adds them to another layer. Everything seems to be working up to the dissolve call. I'm trying to feed a feature collection to arcgis.features.analysis.dissolve_boundaries(), but I keep getting an error that I can't fix.
The jobs fails and the error it produces is "Connection reset by peer: socket write error". What does that even mean? What could be causing this?
There more to the script, but here's the bit that makes the feature collection and tries to call dissolve_boundaries():
tfset = arcgis.features.FeatureSet(tfeatures)
tfcollection = arcgis.features.FeatureCollection.from_featureset(tfset)
result = arcgis.features.analysis.dissolve_boundaries(input_layer=tfcollection)
and here's the traceback:
Exception                                 Traceback (most recent call last)
/tmp/ipykernel_27/2488076861.py in <cell line: 249>()
    354     tfcollection = arcgis.features.FeatureCollection.from_featureset(tfset)
    355
--> 356     diss = arcgis.features.manage_data.dissolve_boundaries(tfcollection)
    357
    358     print('uploading features\n')
/opt/conda/lib/python3.9/site-packages/arcgis/features/manage_data.py in dissolve_boundaries(input_layer, dissolve_fields, summary_fields, output_name, context, gis, estimate, multi_part_features, future)
    277         fn=gis._tools.featureanalysis._tbx.dissolve_boundaries, **kwargs
    278     )
--> 279     return gis._tools.featureanalysis.dissolve_boundaries(**params)
    280
    281
/opt/conda/lib/python3.9/site-packages/arcgis/_impl/tools.py in dissolve_boundaries(self, input_layer, dissolve_fields, summary_fields, output_name, context, estimate, multi_part_features, future)
   3308         if future:
   3309             return gpjob
-> 3310         return gpjob.result()
   3311
   3312     # ----------------------------------------------------------------------
/opt/conda/lib/python3.9/site-packages/arcgis/geoprocessing/_job.py in result(self)
    230             return None
    231         if self._is_fa:
--> 232             return self._process_fa(self._future.result())
    233         elif self._is_ra:
    234             return self._process_ra(self._future.result())
/opt/conda/lib/python3.9/concurrent/futures/_base.py in result(self, timeout)
    444                     raise CancelledError()
    445                 elif self._state == FINISHED:
--> 446                     return self.__get_result()
    447                 else:
    448                     raise TimeoutError()
/opt/conda/lib/python3.9/concurrent/futures/_base.py in __get_result(self)
    389         if self._exception:
    390             try:
--> 391                 raise self._exception
    392             finally:
    393                 # Break a reference cycle with the exception in self._exception
/opt/conda/lib/python3.9/concurrent/futures/thread.py in run(self)
     56
     57         try:
---> 58             result = self.fn(*self.args, **self.kwargs)
     59         except BaseException as exc:
     60             self.future.set_exception(exc)
/opt/conda/lib/python3.9/site-packages/arcgis/geoprocessing/_support.py in _future_op(gptool, task_url, job_info, job_id, param_db, return_values, return_messages)
    326     return_messages,
    327 ):
--> 328     job_info = _analysis_job_status(gptool, task_url, job_info)
    329     resp = _analysis_job_results(gptool, task_url, job_info, job_id)
    330
/opt/conda/lib/python3.9/site-packages/arcgis/geoprocessing/_support.py in _analysis_job_status(gptool, task_url, job_info)
    244
    245                     if job_response.get("jobStatus") == "esriJobFailed":
--> 246                         raise Exception("Job failed.")
    247                     elif job_response.get("jobStatus") == "esriJobCancelled":
    248                         raise Exception("Job cancelled.")
Exception: Job failed.
NickNuebel
It looks like the dissolve call only accepts service layers, not feature collections? The docs are little confusing, but that is, apparently, the only thing that works.
NickNuebel
