Dataframe works in IDE but not in AGO notebook
1972
09-15-2022 03:02 AM
HaydenWilson3
Good day.
I am experiencing some strange behaviour from a Notebook in ArcGIS Online.
I want to convert a related table into a pandas dataframe. when I run this script locally on my machine it runs fine:
from arcgis.gis import GIS
from arcgis.features import FeatureLayerCollection
import tempfile
import pandas as pd
from datetime import datetime, timedelta
import numpy as np
# ArcGIS Online Login
gis = GIS(url='https://XXXXXXX.maps.arcgis.com/', username='XXXX', password='XXXXXXX')
#create a temp scratch workspace
tmpdir = tempfile.TemporaryDirectory()
download_folder = tmpdir.name
fl = gis.content.get('8fbdac5a21ae4fa8a72b7fb6bd96e6ca')
items = fl.tables[0]
df = pd.DataFrame.spatial.from_layer(items)
print(df)
Yet when I run this slightly amended version in ArcGIS Online from a notebook:
import tempfile
import pandas as pd
import numpy as np
gis = GIS("home")
print(df)
I get the following error:
IntCastingNaNError                        Traceback (most recent call last)
File /opt/conda/lib/python3.9/site-packages/arcgis/features/geo/_accessor.py:2688, in GeoAccessor.from_layer(layer)
   2686     from arcgis.features.geo._io.serviceops import from_layer
-> 2688     return from_layer(layer=layer)
   2689 except ImportError:
File /opt/conda/lib/python3.9/site-packages/arcgis/features/geo/_io/serviceops.py:187, in from_layer(layer, query)
    186     raise ValueError("Invalid inputs: must be FeatureLayer or Table")
--> 187 sdf = layer.query(where=query, as_df=True)
    188 sdf.spatial._meta.source = layer
File /opt/conda/lib/python3.9/site-packages/arcgis/features/layer.py:3720, in Table.query(self, where, out_fields, time_filter, return_count_only, return_ids_only, return_distinct_values, group_by_fields_for_statistics, statistic_filter, result_offset, result_record_count, object_ids, gdb_version, order_by_fields, out_statistics, return_all_records, historic_moment, sql_format, return_exceeded_limit_features, as_df, having, **kwargs)
   3718 import pandas as pd
-> 3720 df = self._query_df(url, params)
   3721 dt_fields = [
   3722     fld["name"]
   3723     for fld in self.properties.fields
   3724     if fld["type"] == "esriFieldTypeDate"
   3725 ]
File /opt/conda/lib/python3.9/site-packages/arcgis/features/layer.py:3308, in FeatureLayer._query_df(self, url, params, **kwargs)
   3307 if dtypes:
-> 3308     df = df.astype(dtypes)
   3310 if "SHAPE" in featureset_dict:
File /opt/conda/lib/python3.9/site-packages/pandas/core/generic.py:5799, in NDFrame.astype(self, dtype, copy, errors)
   5797 if col_name in dtype:
   5798     results.append(
-> 5799         col.astype(dtype=dtype[col_name], copy=copy, errors=errors)
   5800     )
   5801 else:
File /opt/conda/lib/python3.9/site-packages/pandas/core/generic.py:5815, in NDFrame.astype(self, dtype, copy, errors)
   5813 else:
   5814     # else, only a single dtype is given
-> 5815     new_data = self._mgr.astype(dtype=dtype, copy=copy, errors=errors)
   5816     return self._constructor(new_data).__finalize__(self, method="astype")
File /opt/conda/lib/python3.9/site-packages/pandas/core/internals/managers.py:418, in BaseBlockManager.astype(self, dtype, copy, errors)
    417 def astype(self: T, dtype, copy: bool = False, errors: str = "raise") -> T:
--> 418     return self.apply("astype", dtype=dtype, copy=copy, errors=errors)
File /opt/conda/lib/python3.9/site-packages/pandas/core/internals/managers.py:327, in BaseBlockManager.apply(self, f, align_keys, ignore_failures, **kwargs)
    326     else:
--> 327         applied = getattr(b, f)(**kwargs)
    328 except (TypeError, NotImplementedError):
File /opt/conda/lib/python3.9/site-packages/pandas/core/internals/blocks.py:591, in Block.astype(self, dtype, copy, errors)
    589 values = self.values
--> 591 new_values = astype_array_safe(values, dtype, copy=copy, errors=errors)
    593 new_values = maybe_coerce_values(new_values)
File /opt/conda/lib/python3.9/site-packages/pandas/core/dtypes/cast.py:1309, in astype_array_safe(values, dtype, copy, errors)
   1308 try:
-> 1309     new_values = astype_array(values, dtype, copy=copy)
   1310 except (ValueError, TypeError):
   1311     # e.g. astype_nansafe can fail on object-dtype of strings
   1312     #  trying to convert to float
File /opt/conda/lib/python3.9/site-packages/pandas/core/dtypes/cast.py:1257, in astype_array(values, dtype, copy)
   1256 else:
-> 1257     values = astype_nansafe(values, dtype, copy=copy)
   1259 # in pandas we don't store numpy str dtypes, so convert to object
File /opt/conda/lib/python3.9/site-packages/pandas/core/dtypes/cast.py:1168, in astype_nansafe(arr, dtype, copy, skipna)
   1167 elif np.issubdtype(arr.dtype, np.floating) and np.issubdtype(dtype, np.integer):
-> 1168     return astype_float_to_int_nansafe(arr, dtype, copy)
   1170 elif is_object_dtype(arr):
   1171
   1172     # work around NumPy brokenness, #1987
File /opt/conda/lib/python3.9/site-packages/pandas/core/dtypes/cast.py:1213, in astype_float_to_int_nansafe(values, dtype, copy)
   1212 if not np.isfinite(values).all():
-> 1213     raise IntCastingNaNError(
   1214         "Cannot convert non-finite values (NA or inf) to integer"
   1215     )
   1216 return values.astype(dtype, copy=copy)
IntCastingNaNError: Cannot convert non-finite values (NA or inf) to integer
During handling of the above exception, another exception occurred:
Exception                                 Traceback (most recent call last)
Input In [5], in <cell line: 17>()
     15 utr_items = predeploymnet_master_fl.tables[0]
     16 print(utr_items)
---> 17 utr_df = pd.DataFrame.spatial.from_layer(utr_items)
     18 print(utr_df)
File /opt/conda/lib/python3.9/site-packages/arcgis/features/geo/_accessor.py:2697, in GeoAccessor.from_layer(layer)
   2692     raise Exception(
   2693         "Malformed response from server, could not load the dataset: %s"
   2694         % str(je)
   2695     )
   2696 except Exception as e:
-> 2697     raise Exception("Could not load the dataset: %s" % str(e))
Exception: Could not load the dataset: Cannot convert non-finite values (NA or inf) to integer
Can anyone please assist?
HaydenWilson3
I have tried using:
df = items.query(as_df=True, out_fields = ['XXX','XXX','XXX'])
but sadly some of the fields contain (NA or inf) values
EarlMedina
Are there any obvious difference between the two environments? Are the arcgis package versions the same? What about the python versions?
HaydenWilson3
Okay, Figured it out!
In ArcGIS Online, Rather than using :
Use:
gis.content.get('8fbdac5a21ae4fa8a72b7fb6bd96e6ca').tables[0].query().sdf
