DataFrame spatial plot not changing Arcgis map
2268
08-28-2019 04:19 AM
bgrbgr
I'm trying to plot heat-map of the pandas.df over a Arcgis gray map in jupyter notebook, but the map is not changing (not matter what render style).
maybe because: (?) In the anaconda prompt jupyter nbextension list
- Validating: problems found: require? X arcgis/mapview
The problem is the same also after I create new env in jupyter and install arcgis again.
df = pd.read_csv(csv_path)sdf = pd.DataFrame.spatial.from_xy(prop_df, 'LONGITUDE','LATITUDE')some_map = gis.map('Portland, OR')some_map .basemap = 'streets'some_map
sdf.spatial.plot(map_widget=some_map )
ChristopherLaBorde
I'm having the same problem, following Atma Mani‌'s tutorial from the GeoDevPDX2018 talk in the jupyter notebook on github..
prop_sdf.spatial.plot(map_widget=pdx_map)
returns True
but doesn't update the map with colored dots.
Miguel-Fernandez
I am also experiencing the same issue.
# Convert pandas dataframe to Esri's spatially enabled dataframe
sdf = pd.DataFrame.spatial.from_xy(df1, 'longitude', 'latitude')‍‍
from arcgis.gis import *
gis = GIS()
m = GIS().map()
m.center = [36.081179, -79.556955]
m.zoom = 9
m
# Add sdf to the map
sdf.spatial.plot(kind='map', map_widget=m)
Line 13 returns True with no update to the map. Any guidance or tips would be appreciated.
#arcgisapiforpython#arcgisapi#arcgis api for python 1.6.2#python3.6
Miguel Fernandez
