Creating new user via ArcGIS API for Python
9287
14
02-17-2020 10:56 PM
PhilippeRieffel1
Hey all,
i am trying to automate the creation of named users on arcgis online. I am basically using the code from the example notebooks. And it always fails
the gis object is created with an administrator connection, and i tested it with version 1.7.0 as well, same error. So, my question would be, is there any way to get a more detailed response from the api, like the actual response of the rest call or something? Or in general, what am i doing wrong here?
Thanks for your input.
Fuentes
I have the same problem and can't find a solution anywhere.
Updating and deleting an account works.
pajamas
Hi
I had the same issue and could solve it by setting the New Member Defaults. You find them on your ArcGIS Online Account under Organisation > Settings > New Member Defaults
NicoleHuang1
This solved my problem, thank you so much!
jorisfrenkel
I am running into the same issue now, but only in ArcGIS Online. However, in ArcGIS Pro, it works, but my version of Pro is a bit older, 1.8.1.
AFackler_NAPSG
Ran into this same issue as well. What I found was I was out of "Creator" roles in my hub organization and that was causing the creation of new users to be created. When I checked my user defaults and modified the default role to something else, I was good to go
