Creating a Group Layer Item
2219
08-29-2024 07:36 AM
Desharin
I've been trying to add a Group Layer to ArcGIS Online using the Python API, but my attempts have only been partly succesful. Below you'll find some code similar to what I've been doing. I've used the Group Layer spec as shown here.
from arcgis import GIS
import json
gis = GIS(url = AGO_URL, username = AGO_USER, password = AGO_PASS)
itemProperties = {
    'type': 'Group Layer',
    'description': 'Some Description',
    'title': 'Some Title',
    'tags': ['Tag1', 'Tag2'],
    'snippet': 'Some Snippet',
    'accessInformation': 'Some Access Information',
    'licenseInfo': 'Some License Info',
    'commentsEnabled': False,
    'access': 'org',
    'text': json.dumps(
            "id": "groupLayer",
            "layerType": "GroupLayer",
            "title": "US Census",
            "layers": [
                    "id": "Census_6999",
                    "title": "Census - states",
                    "url": "https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/3",
                    "layerType": "ArcGISFeatureLayer"
                    "id": "Census_616",
                    "title": "Census - Detailed Counties",
                    "url": "https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/2",
gis.content.add(
    item_properties = itemProperties,
    thumbnail = 'Some thumbnail url',
    metadata = None,
    owner = None,
    folder = None
This will successfully add the item as a Group Layer to ArcGIS Online, with title, description, etc. all working. The 2 layers will also show up as layers in the item. However, if I open the item in the Map Viewer, no layers will be shown.
Please advise.
Clubdebambos
MVP Regular Contributor
Hi @Desharin
Add the following typeKeywords to your itemProperties.
    "typeKeywords": [
        "ArcGIS API for JavaScript",
        "Group Layer",
        "Map"
There is also no need for json.dumps in the "text" property.
Let me know if that works for you?
Cheers,
Glen
~ learn.finaldraftmapping.com
Clubdebambos
Hi @Desharin
    "typeKeywords": [
        "Group Layer",
        "Map"
Cheers,
Glen
Desharin
Sorry for the late response, but this seems  to work! Thank you very much!
