Create users and roles from a CSV file
3123
10-12-2023 11:39 AM
chill_gis_dude
I am trying to work through the code example to bulk add users with csv on this page:
https://enterprise.arcgis.com/en/server/10.8/administer/windows/example-create-users-and-roles-from-...
The code has not been updated from python 2 to python 3 and I am getting stuck on this error message:
gaierror: [Errno 11001] getaddrinfo failed
The code is below as well
# This script creates a bank of users and roles given a comma-separated text file
#  They should be listed in the following format and saved in a file with a .txt extension:
#  User,Role,RoleType,Password,EMail,FullName,Description
#  John,Admins,ADMINISTER,changeme,[email protected],John Doe,Server admin
#  Jane,Publishers,PUBLISH,changeme,[email protected],Jane Doe,Server publisher
#  Etc.
import json, urllib,httplib
# For system tools
import sys
# For reading passwords without echoing
import getpass
def main(argv=None):
    # Ask for admin/publisher user name and password
    username = raw_input("Enter user name: ")
    password = getpass.getpass("Enter password: ")
    # Ask for server name & port
    serverName = raw_input("Enter server name: ")
    serverPort = 6080
    # Input File with the Role and user information
    inFile = raw_input("Path to comma-delimited text file containing users and roles: ")
    # InFile = r"C:\testing\agsUsersRoles.txt"
    opnFile = open(inFile,'r')
    # Dictionaries to store user and role information
    roles = {}
    users = {}
    addUserRole = {}
    # Read the next line
    ln = opnFile.readline()
    # Counter to get through the column header of the input file
    num = 0
    while ln:
        if num == 0:
            pass # File header
        else:
            # Split the current line into list
            lnSplt = ln.split(",")
            # Build the Dictionary to add the roles
            roles[lnSplt[1]] = {lnSplt[2]:lnSplt[len(lnSplt) -1].rstrip()}
            # Add the user information to a dictionary
            users["user" + str(num)] = {"username":lnSplt[0],"password":lnSplt[3],"fullname":lnSplt[5],"email":lnSplt[4],"description":lnSplt[-1].rstrip()}
            # Store the user and role type in a dictionary
            if addUserRole.has_key(lnSplt[1]):
                addUserRole[lnSplt[1]] =  addUserRole[lnSplt[1]] + "," + lnSplt[0]
            else:
                addUserRole[lnSplt[1]] = lnSplt[0]
        # Prepare to move to the next line
        num +=1
    # Get a token and connect
    token = getToken(username, password,serverName,serverPort)
    if token == "":
            sys.exit(1)
    # Call helper functions to add users and roles
    addRoles(roles, token,serverName,serverPort)
    addUsers(users,token,serverName,serverPort)
    addUserToRoles(addUserRole,token,serverName,serverPort)
def addRoles(roleDict, token, serverName, serverPort):
    for item in roleDict.keys():
        # Build the dictionary with the role name and description
        roleToAdd = {"rolename":item}
        # Load the response
        jsRole = json.dumps(roleToAdd)
        # URL for adding a role
        addroleURL = "/arcgis/admin/security/roles/add"
        params = urllib.urlencode({'token':token,'f':'json','Role':jsRole})
        headers = {"Content-type": "application/x-www-form-urlencoded", "Accept": "text/plain"}
        # Build the connection to add the roles to the server
        httpRoleConn = httplib.HTTPConnection(serverName, serverPort)
        httpRoleConn.request("POST",addroleURL,params,headers)
        response = httpRoleConn.getresponse()
        if (response.status != 200):
            httpRoleConn.close()
            print "Could not add role."
            return
        else:
            data = response.read()
            # Check that data returned is not an error object
            if not assertJsonSuccess(data):
                print "Error when adding role. " + str(data)
                return
            else:
                print "Added role successfully"
        # Assign a privilege to the recently added role
        assignAdminUrl = "/arcgis/admin/security/roles/assignPrivilege"
        params = urllib.urlencode({'token':token,'f':'json',"rolename":item, "privilege":roleDict[item].keys()[0]})
        # Build the connection to assign the privilege
        httpRoleAdminConn = httplib.HTTPConnection(serverName, serverPort)
        httpRoleAdminConn.request("POST",assignAdminUrl,params,headers)
        response = httpRoleAdminConn.getresponse()
            httpRoleAdminConn.close()
            print "Could not assign privilege to role."
            return
        else:
                print "Error when assigning privileges to role. " + str(data)
                return
            else:
                print "Assigned privileges to role successfully"
def addUsers(userDict,token, serverName, serverPort):
    for userAdd in userDict:
        jsUser = json.dumps(userDict[userAdd])
        # URL for adding a user
        addUserURL = "/arcgis/admin/security/users/add"
        params = urllib.urlencode({'token':token,'f':'json','user':jsUser})
        # Build the connection to add the users
        httpRoleConn.request("POST",addUserURL,params,headers)
def addUserToRoles(userRoleDict,token, serverName, serverPort):
    for userRole in userRoleDict.keys():
        # Using the current role build the URL to assign the right users to the role
        addUserURL = "/arcgis/admin/security/roles/addUsersToRole"
        params = urllib.urlencode({'token':token,'f':'json',"rolename":userRole,"users":userRoleDict[userRole]})
            print "Could not add user to role."
            return
        else:
                print "Error when adding user to role. " + str(data)
                return
            else:
                print "Added user to role successfully"
def getToken(username, password, serverName, serverPort):
    # Token URL is typically http://server[:port]/arcgis/admin/generateToken
    tokenURL = "/arcgis/admin/generateToken"
    params = urllib.urlencode({'username': username, 'password': password,'client': 'requestip', 'f': 'json'})
    # Connect to URL and post parameters
    httpConn = httplib.HTTPConnection(serverName, serverPort)
    httpConn.request("POST", tokenURL, params, headers)
    # Read response
    response = httpConn.getresponse()
        httpConn.close()
        print "Error while fetching tokens from admin URL. Please check the URL and try again."
        return
    else:
        httpConn.close()
            return
        # Extract the token from it
        token = json.loads(data)
        return token['token']
# A function that checks that the input JSON object
#  is not an error object.
def assertJsonSuccess(data):
    obj = json.loads(data)
    if 'status' in obj and obj['status'] == "error":
        print "Error: JSON object returns an error. " + str(obj)
        return False
    else:
        return True
# Script start
if __name__ == "__main__":
    sys.exit(main(sys.argv[1:]))
David_McRitchie
Hey George,
For what version of Enterprise is this for? The documentation is for version 10.8.1 so this might be where we are hitting the error.
The following sample might be more useful if you are using a version later than 10.8.1.
Hope that helps,
David
Esri UK -Technical Support Analyst
SGTomlins
I hacked this to work with 3.7....
Now I get the follwing error... 😞
fumbling thru an example... i am..
File "C:\SGT\ESRI\Python\ArcGIS Enterprise\AddUserToEntPortal-fumblethru.py", line 58, in generateToken
if responseJSON.has_key('error'):
AttributeError: 'dict' object has no attribute 'has_key'
# Requires Python 2.7+
# Demonstrates how to add users to the ArcGIS Enterprise portal in bulk
# For Http calls
import urllib3, urllib, json
import urllib.parse
import urllib.response
from urllib.request import urlopen
from notebook.notebookapp import raw_input
# This function connects to the portal and adds members to it from a collection
# def createUsers(username,password, portalUrl, provider,userParamsQ):
# ## these are the tinkerbell-az server credentials: DEVELOPMENT server
username = "sitdg5g45634min"
password = "fdghfdghfdghfdghfdghv"
portalUrl = "https://tinkerbell-az.ci.janesville.wi.us/devportal"
serverUrl = "https://tinkerbell-az.ci.janesville.wi.us/devserver/admin"
# This function gets a token from the portal
#def generateToken(username, password, serverUrl, json_obj=None):
def generateToken(username, password, serverUrl):
parameters = urllib.parse.urlencode({'username' : username,
'password' : password,
'client' : 'referer',
'referer': portalUrl,
'expiration': 600,
'f' : 'json'})
pmans = parameters.encode('utf-8')
try:
#response = urllib3.urlopen(portalUrl + '/sharing/rest/generateToken?', parameters).read()
response = urllib.request.urlopen(serverUrl + '/generateToken?', pmans)
#response = urllib.request.urlopen(serverUrl + '/generateToken?', pmans).read()
responsestring = response.read().decode('utf-8')
json_obj = json.loads(responsestring)
#print('this is the response :' + json_obj)
except Exception as e:
#raise SystemExit( 'Unable to open the url %s/sharing/rest/generateToken' % (portalUrl))
raise SystemExit('Unable to open the url %s/' % (serverUrl))
# responseJSON = json.loads(response.strip(' \t\n\r'))
responseJSON = json.loads(responsestring)
#content = json.loads(r.decode('utf-8').replace('\n', ''))
# Log results
errDict = responseJSON['error']
if int(errDict['code'])==498:
message = 'Token Expired. Getting new token... '
token = generateToken(username,password, serverUrl)
else:
message = 'Error Code: %s \n Message: %s' % (errDict['code'],
errDict['message'])
raise SystemExit(message)
token = responseJSON.get('token')
return token
print('...Connecting to ' + portalUrl)
print('...Adding users ')
