Copy Raster Clip Setting parameter?
2071
09-19-2023 08:14 AM
InvenergyGIS_User
I've been looking into creating a tool using the ArcGIS API for Python. I am trying to use the Copy Raster function to extract by mask based off Esri Documentation. Does anybody know what exactly is supposed to be entered into the 'clip_setting' parameter? Documentation doesn't say much other than a string. I have a polygon boundary I wanted to use to clip.
David_McRitchie
Hey,
I came across the same functionality within the REST API and the documentation provides a more useful example. Hopefully this helps steer this in the right direction.
Many thanks,
David
Esri UK -Technical Support Analyst
InvenergyGIS_User
Thank you!
InvenergyGIS_User
Thanks for that link. I'm still getting tripped up on the formatting because the API requires a string, when the REST API requires a JSON. I've been troubleshooting this but am getting stumped.
clip_setting = "extent='-8013156.87983135 5096812.30094792 -8010362.15091558 5099064.80462686"
Any thoughts?
