Hi, I have an sdf from a feature layer in the EPSG 5514 coordinate system, and it returns points with coordinates in meters. After applying a query where I call "out_sr=4326" at the end, I get the coordinates in degrees, but they are a bit off by a few meters. Is there another way to trnsform the coordinates or the whole sdf into 4326? thanks
sdf = znacky.query(where="NAPIS like '%=invalida%' or OZNACENI like '%IP12O%' or NAPIS like '%= invalida%' or NAPIS like '%X invalida%' or NAPIS like '%x invalida%' or NAPIS like '%.invalida%' or NAPIS like '%. invalida%' or NAPIS like '%.invalida%' or CISZN like '%IP1201%' and platnost_t not like '%Archiv%'",out_sr=4326 ).sdf
You might be able to specify a datum transformation e.g 15965 https://epsg.io/5514 (I have no idea which would be the best)
https://epsg.org/search/by-name/sessionkey/lkb8q2c1cc/transformation_page/40/#transformation
'datumTransformation' parameter https://developers.arcgis.com/rest/services-reference/enterprise/query-feature-service-layer-.htm
datumTransformation=1623
