conda update conda
10966
14
09-21-2020 12:51 AM
wwnde
I recently updated ArcPro to version 2.6.1 since then, notebooks is not taking any conda instruction.
I have been through all discussed in this post, unistalled and installed both ArcPro and Anaconda multiple time but still get whenever I do any conda install or conda update.
'conda' is not recognized as an internal or external command, operable program or batch file.
Note: you may need to restart the kernel to use updated packages.
Is this a version bug or I completely missed something? Your help will highly be appreciated.
DanPatterson
MVP Esteemed Contributor
Warren, as I suggested to the original post... Tech Support might be best
... sort of retired...
wwnde
I got this working in ArcPro 2.6.2. Python 3.8.3. The issue is, only azure-blob-storage version 2.1.0 works. So clone the environment and  pip install azure-storage-blob==2.1.0 . Dont do this through the Python Management Package in Arcpo because it installs a higher version. Let me know how you go. Working perfectly for me. With this, I was able to read and write to the blob both .csv and spatially enabled dataframes. Happy to share the code.
Cheers
WarrenMedernach
Thanks so much for the info William.
The execution and install of the azure-storage-blob==2.1.0 didn't resolve the issue, but it did present a different error this time:  Cannot import name 'BlobServiceClient'
I decided to try to 'upgrade' the module with: install azure-storage-blob --upgrade. Once that completed I fired up Pro and was able to successfully create an Azure Profile with the OptimizeRaster toolbox so it seems to be functioning.
As a side note, the test code that all the posts above were trying to execute from Pro:
from azure.storage.blob import BlockServiceClient
Still fails...
wwnde
Yap, II didn't need to use;
I tried to include it and yes it failed. There IA currently an open issue on the matter though
KelechiChibuikem
Hi I am new to this python thing and arc gis pro
I can do some basic designs with arc gis pro.
I want to use the OSMNX feature in my note book , but it dosend import. It says No module named 'osmnx'
