Clone python environment field
2535
04-07-2019 10:57 PM
HabibaAtify
I want to add Tensoflow library to ArcGIS Pro. so for adding new library first, I have to clone the python environment . when I clone the python environment I face with that error.
CondaError: CondaHTTPError: HTTP 000 CONNECTION FAILED for url <https://conda.anaconda.org/esri/win-64/arcgispro-2.3-0.tar.bz2>
Elapsed: -
An HTTP error occurred when trying to retrieve this URL.
HTTP errors are often intermittent, and a simple retry will get you on your way.
Elapsed: -
Elapsed: -
How can solve it ?
Tags (1)
KjellTimalm
Did you get any solution in this matter? Have the same problem.
JasonLee9
Happened to me.
The fix was creating to local system variables for proxy server.
Variables:
HTTP_PROXY
HTTPS_PROXY
SteveScott
Is there a way to clone the environment without using an http connection to access this file? Our server is under pretty tight security.
