Can arcgis.apps.dashboard be used with the new dashboards?
3314
11-30-2022 02:53 AM
abrown8
Hi All
Reading the arcgis.apps.dashboard module documentation, it says "Deprecated as ArcGIS Dashboards Classic  is retiring."
Can this submodule/classes still be used to create the new type of dashboards? Will I run into any problems by automating creation?
Thank you
Ali
SimonSchütte_ct
MVP Regular Contributor
I hope there will be a module for the new Dashboard Version with a more stable API implementation. Being able to automate the creation process is really important.
PeterKnoop
Any word on whether a module that is compatible with the current version of ArcGIS Dashboards will be released?
abrown8
I haven't heard anything further about this. I did however find a (long) workaround for automation by cloning an existing dashboard, using fs.get_data(), editing the json definition and saving. This post helped me out.
Nb. Depending on when the original dashboard was created the json definition might be different to a newer one so your code may not always work.
SimonSchütte_ct
I asked this at the last Dev Summit in Palm Springs. The development of the new Dashboards is too dynamic to keep the API up to date. They are waiting for the Dashboards development to settle down, before they write a public Python API.
So as far as I know, the old API is not supported with the new Dashboards and there is no alternative at the moment.
I created a new idea here: https://community.esri.com/t5/arcgis-api-for-python-ideas/update-the-arcgis-apps-dashboard-to-suppor...
Releated ideas:
Ability to push updates to dashboards in productio... - Esri Community
Operation dashboard - Add the ability to save as a... - Esri Community
