bug pip pipenv install arcgis
11074
6
04-30-2023 03:24 PM
degarzonm
Hello i just found a bug at the moment of installing arcgis with pip or pipenv, no matter if i try with or without dependencies the error is the same
error in arcgis setup command: 'install_requires' must be a string or list of strings containing valid project/version
requirement specifiers; [32m[1mExpected[0m end or semicolon (after version specifier)
keyring >=19,<=21.8.*
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
[0m
This is likely caused by a bug in [32marcgis[0m. Report this to its maintainers.
GilMastrapa
Yes, locally is allowing to install up to 1.9.1, but for cloud functions to work it has to be 1.8.* . Here is a topic with more info on one of the broken dependencies (urllib)
https://community.esri.com/t5/arcgis-api-for-python-questions/error-init-got-an-unexpected-keyword-a...
LinasSpraunius
I've got the same error. Any ideas on how to solve it?
GISAdministrator_LMCC
+ 1: Would love to know of a fix also
GilMastrapa
Any luck??? Incredible that we can't deploy our function because of this error on the cloud(it was working properly previously!). Cloud function uses pip, not conda.
Collecting arcgis==2.0.1 (from -r requirements.txt (line 4))
Using cached arcgis-2.0.1.tar.gz (13.9 MB)
Installing build dependencies ... done
Getting requirements to build wheel ... done
Installing backend dependencies ... done
Preparing metadata (pyproject.toml) ... error
error: subprocess-exited-with-error
× Preparing metadata (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [3 lines of output]
error in arcgis setup command: 'install_requires' must be a string or list of strings containing valid project/version requirement specifiers; Expected end or semicolon (after version specifier)
keyring >=23.3.*
[end of output]
GilMastrapa
Update.
Downgrading arcgis to 1.9.1 solved the issues (using python 3.8), but at the cost of having to use a dated version of the API.
Several inconsistencies with the 2.* version dependencies.
Did you find any other solution? @degarzonm  @GISAdministrator_LMCC  @LinasSpraunius
btripp
I am also running into the same problem. I tried multiple versions of arcgis, as well as different versions of python - but had no luck until I used python==3.8.10, and arcgis==1.8.5.post3. Not a solution, but an intermediate fix until the arcgis folks fix the issue.
For any windows users, here is a .bat script you can run to set up a python venv with arcgis==1.8.5.post3 (assuming you have python==3.8.x installed and are on a windows machine):
@echo off
setlocal
REM Set the paths
set PYTHON_DIR=C:\Users\%USERNAME%\AppData\Local\Programs\Python\Python38
set VENV_NAME=py38
REM Create a new virtual environment
%PYTHON_DIR%\python.exe -m venv %VENV_NAME%
REM Activate the virtual environment
call %VENV_NAME%\Scripts\activate.bat
REM Install the packages
pip install --upgrade pip setuptools wheel
pip install "keyring>=19,<=21.8.*"
pip install --use-pep517 arcgis==1.8.5.post3
endlocal
GilMastrapa
