Best way to figure out what kind of layer I've got?
1175
04-08-2019 09:01 AM
by Anonymous User
Not applicable
I'll try to start simple and add detail if necessary, but my question is general - "Layers" in the ArcGIS API for Python refers to so many things, I need a way to discern what kind of layer I've got in any situation, so that I know what properties are available.
I need to list layers in web maps. ArcGISMapServiceLayer, which can be grouped, is a troublemaker, because of sublayers and groups (each of which is a 'layer.'). I need to check whether or not I am at a group layer, and therefore need to keep "going down" before I can interrogate the layer for its popupInfo, field name, etc...
I can use json, but I'm wondering if there is a more direct way. Can I check for a property without directly loading in the JSON?
if lyr.layerType == 'ArcGISMapServiceLayer':
   l1_json = json.loads(str(lyr))
      if l1_json.get('layers'):
ie. if lyr.layers is None or something? I've tried this and had no luck.
Thank you for your time,
Randy McGregor
by Anonymous User
Not applicable
Actually, you can interrogate the objects directly. This works:
   if 'layers' in lyr:
      Do something
   else:
      Do something els
No need to load the json for this particular check.
