ARCGIS Rest API with python addfeatures question
6200
10
01-31-2019 09:08 AM
Larry
I am uploading some Points and Lines into ArcGIS Online hosted feature services using a python program the ArcGIS Rest Api. The points work fine but I am having trouble getting the correct format for adding the lines.
For the Points:
    "features":
            "geometry": {
                  "x": x,
                  "y": y
            "attributes": {
                "RECORD_ID": RECORD_ID,
                "DEVICE_ID": DEVICE_ID,
                "DATE_TIME": DATE_TIME,
                "LONGITUDE": LONGITUDE,
                "LATITUDE": LATITUDE,
Works.
For the lines If have tried:
     "features":
            "paths":[
                [x,y],[x1,y1]],
                "spatialReference": {"wkid" : 4326},
            "attributes": {
                "DEVICE_NAME": DEVICE_NAME,
                "SPEED": SPEED,
                "HEADING": HEADING,
FAILS.
The error I get is:
"No JSON object could be decoded"
Any idea what I am doing wrong?
Larry
Tags (1)
Larry
Thanks to both of you. I thought I had created a wgs84 lat/long projection but AGOL turned it into web mecator. It is inserting the coordinates correctly when I set the projection to 4236 on the input so I assumed AGOL was doing the conversion. I am getting lines now but AGOL still complains about there was no json object to decode. Thanks for all your help
