ArcGIS Python API Fire Analysis
3278
12-08-2020 08:24 PM
KrishV
Hi Everyone,
I'm trying to use California wildfires 2017 - Thomas Fire analysis Sample provided in ArcGIS Python API Samples. I have used sentinel imagery to do the same analysis but I always end up getting black imagery (All 0s). Can you please suggest where I'm doing wrong?
import arcgis
from arcgis import *
from arcgis.mapping import MapImageLayer
gis = GIS(profile="krishna_dev")
#Sentinel2
sentinel_item = gis.content.search('title:Sentinel2', 'Imagery Layer', outside_org=True)[0]
sentinel = sentinel_item.layers[0]
sentinel_item
aoi = {'spatialReference': {'latestWkid': 3857, 'wkid': 102100}, 'type': 'extent',
       'xmax': 9028482.969, 'xmin': 8908018.212, 'ymax': 2478700.211, 'ymin': 2248166.133}
arcgis.env.analysis_extent = {'xmax': 9028482.969, 'xmin': 8908018.212, 'ymax': 2478700.211, 'ymin': 2248166.133,
                              "spatialReference":{"wkid":102100,"latestWkid":3857}}
sentinel.extent = aoi
import pandas as pd
from datetime import datetime
selected = sentinel.filter_by(where="(Category = 1)",
                             time=[datetime(2020, 4, 3), datetime(2020, 4, 15)],
geometry=arcgis.geometry.filters.intersects(aoi))
df = selected.query(out_fields="acquisitiondate, name, cloudcover",
                    order_by_fields="acquisitiondate").sdf
df['acquisitiondate'] = pd.to_datetime(df['acquisitiondate'], unit='ms')
df.tail()
prefire = sentinel.filter_by('OBJECTID in ( 10127407, 10187367)') # 2020-04-03
prefire = prefire.blend()
midfire = sentinel.filter_by('OBJECTID in (10304749, 10304746)') # 2020-04-13
midfire = midfire.blend()
from arcgis.raster.functions import *
extracted_band = extract_band(midfire, [13,12,4])
extracted_band_prefire = extract_band(prefire, [13,12,4])
nbr_prefire  = band_arithmetic(prefire, "(b9 - b13) / (b9 + b13) + 2000")
nbr_postfire = band_arithmetic(midfire, "(b9 - b13) / (b9 + b13) + 2000")
nbr_diff = nbr_prefire - nbr_postfir
nbr_diff
burnt_areas = colormap(remap(nbr_diff,
                             input_ranges=[0.1,  0.27,  # low severity
                                           0.27, 0.44,  # medium severity
                                           0.44, 0.66,  # moderate severity
                                           0.66, 1.00], # high severity burn
                             output_values=[1, 2, 3, 4],
                             no_data_ranges=[-1, 0.1], astype='u8'),
                             colormap=[[4, 0xFF, 0xC3, 0], [3, 0xFA, 0x8E, 0], [2, 0xF2, 0x55, 0], [1, 0xE6, 0,    0]])
burnt_areas
Krish
KrishV
Hi @MehdiPira1 ,
I was getting result in ArcGIS Pro using Sentinel Images but same thing is not happening using ArcGIS Python API if I use Sentinel Imagery available in Living Atlas.
However, I have managed to extract burnt areas using Landsat Imagery available in Living Atlas
Krish
MehdiPira1
Hi @KrishV
There is no Band 13 in Sentinel2 and your NBR formula
is different from that of esri.
The correct formula for NBR is
"(b5 - b7) / (b5 + b7+1000)"
 Besides that, you have used
this period of time which means there might be no fire occurred between these dates.
If you visualize prefire and midfire, you might be able to check if a fire has occurred in the images or not prior to further calculations.
Cheers
Mehdi
KrishV
Hi @MehdiPira1 ,
Did you get a chance to check on this?
Krish
KrishV
Hi @MehdiPira1 ,
I have taken the formula from below site:
https://developers.arcgis.com/python/sample-notebooks/wildfire-analysis-using-sentinel-2-imagery/
I have used below formula also but I don't get any desire results:
I have also visualized the midfire image and I see the burnt areas
Krish
MehdiPira1
Hi @KrishV ,
That's bizarre!
Did you try to apply that manually in ArcGIS Pro to see if the process gives the same result or not?
KrishV
Hi @MehdiPira1 ,
Krish
