arcgis.layers module not working
2339
6
01-07-2025 09:43 AM
tad
I'm trying to add an image service to a map. I'm following documentation (https://developers.arcgis.com/python/latest/guide/using-imagery-layers/) that says to use the arcgis.layers module, but I get the following error: ModuleNotFoundError: No module named 'arcgis.layers'
I'm using ArcGIS Pro 3.2, I cloned and updated the active environment...still not found. Any suggestions would be appreciated.
Thanks.
CodyPatterson
MVP Regular Contributor
Hey @tad
Are you importing the arcgis.layers module?
Cody
tad
Yes, @CodyPatterson  that's what is causing the error I'm receiving. Sorry, I should have made that more clear...
DanPatterson
MVP Esteemed Contributor
arcgis 2.4 requires python  >3.10 <3.13
doesn't Pro 3.2 use 3.9?
give this a try
import arcgis
arcgis.__version__
'2.4.0'
from arcgis import layers
dir(layers)
['BasemapService',
 'BasemapServices',
 'BuildingLayer',
 'CSVLayer',
 'EnterpriseMapImageLayerManager',
 'EnterpriseSceneLayerManager',
 'EnterpriseVectorTileLayerManager',
.... snip ...
maybe the clone installed a different versin and "layers" is now a separate module
... sort of retired...
tad
Thanks @DanPatterson. That still didn't work. If it's retired, is there a new (or different) way of adding an image web service?
DanPatterson
its npt retired ... I am
so you are aren't using Pro 3.4 and python 3.11 and the cloning of the environment wouldn't have installed the correct version of the arcgis module, and even if you did install it, you will have to check that is the correct version in the clone
Hannes_Brandt
Hey all,
I ran into the same problem using ArcGIS PRO 3.3.5 (arcgis 2.3.0.4) and this two import variants:
import arcgis.layers
It seems that the arcgis.layers module is simply not part of this arcgis version?
It's just not mentioned in the documentation [1], which is a bit problematic.
In the OGC examples [2], a different approach is mentioned, but this does not work with this version either.
from arcgis.mapping.layers import WMTSLayer, WMSLayer
[1] https://developers.arcgis.com/python/latest/api-reference/arcgis.layers.toc.html
[2] https://developers.arcgis.com/python/latest/samples/publish-ogc-services/#connect-to-your-gis
regards,
Hannes
