arcgis.features.analyze_patterns.interpolate_points does not overwrite.
1122
08-13-2025 08:21 AM
JD5
arcgis.features.analyze_patterns.interpolate_points appears to run successfully and charges credits but does not overwrite the layer passed to 'output_name'.
arcgis.features.analyze_patterns.interpolate_points(
  data_item,
  field = 'value',
  interpolate_option = 9,
  classification_type = 'Manual',
  class_breaks = [50, 100, 150, 200, 300, 500],
  bounding_polygon_layer = boundary_item,
  predict_at_point_layer = point_item,
  output_name = interpolate_item,
  context = {'overwrite': True}
output:
{"cost": 1.101}
{'result_layer': <FeatureCollection>,
 'prediction_error': '',
 'predicted_point_layer': <FeatureCollection>}
Does not overwrite 'interpolate_item' which was created from the very same function call, simply change the output_name parameter to a string.
Is anyone else experiencing the same behavior? Are there any alternatives.
JD5
BUG-000178988
