API key using user role not key privileges
1726
09-26-2025 03:44 PM
AdamMesser1
I was testing the use of the API Key functionality for conducting python automation via the arcgis python api and I expected API Key privileges to apply. However, testing indicated API key privileges were following the user role that owns the key, not the privileges set in the key itself. I'm wondering if there is a bug in the Arcgis API or if I am missing something?
Testing steps:
  • Using ArcGIS Online, I created an API key to test allowing access to organization resources via an automation script. I gave the key one privilege: Admin>Content>View all. This also automatically selects the additional privileges: General>Members>View; General>Content>View content shared with organization; Admin>Members>View all. A referrer url was not designated.
  • The test used arcgis python api version 2.3.0.3. After using gis = arcgis.gis.GIS(api_key="*KEY*”) to authenticate, I was able to retrieve content as expected. However, I was also able to add records (using layer.edit_features(adds=itemList)) which I did not expect. I tried this with an editable feature layer I own and a non-editable layer another account owned. My account role includes General>Features>Edit with full control, so I assumed the API Key was using my user role privileges.
  • To test this, I logged on as a test user with a similar role and created an API Key with the same privileges as described above. The editing capability was available and I was able to add records to the two layers as previously described. I then changed the test user role to only allow General>Content>Create/Update/Delete. The API Key authenticated. As expected, I could not query items from the other accounts. I updated the test role to include Administrative>Content>View All. The data could now be queried as expected. However, the edit test again allowed me to add data to both feature layers. When logged on as the test user directly to AGOL, I was able to manually edit the data for the editable layer, but not for the non-editable layer.
I examined Privileges | Documentation | Esri Developer  to learn about the scope. It appears that the AGOL Portal Service privileges have personal scope “that require additional permissions from your account to perform operations.” However, in this case it seems the privileges for the API Key are being overridden by the user role permissions not enabled by them. When using the arcgis python api, it is not adhering to the privileges of the API Key, nor is it adhering to the privileges of the user role.
This test would suggest if I set up an API Key as an administrator, any workflow using that key via the python api can conduct any action on my site regardless of the privileges in the key. Obviously that is not great.
AdamMesser1
Tested this again. Perhaps it is simpler to ask "Is Item Access under Item Privileges for an API Key supposed to limit access to only checked items?" With a test user account, on ArcGIS Online (not Enterprise), a new API Key was created and given item access to one of the users 3 items. However, the key enabled access all the users private items. That is not my understanding of how the key should work. I ran this test using the Rest API with :
import requests
API_KEY = "MY KEY"
url = "https://www.arcgis.com/sharing/rest/search"
params = {
    "q": "orgid:MY ORG ID",
    "f": "json",
    "num": 100,
    "token": API_KEY,
response = requests.get(url, params=params)
data = response.json()
print(f"Total items visible to key: {data.get('total', 0)}")
I repeated the query using the client id and secret to generate a token, and got the same results as the API Key query. @John-Foster and @Noah-Sager you both have provided input on other API Key posts so hoping perhaps you can help me understand the intent here.
Noah-Sager
Hey @AdamMesser1, sorry for the late response. Are you still facing this issue after the recent update?
AdamMesser1
Thanks for the reply @Noah-Sager We recently updated to Pro 3.5.5 and our group is using the 2.4.1.3 python api. Are you indicating that version as the recent update, or 2.4.1.4? If not, please clarify. Regardless, I can try to carve out some time to test this again.
Noah-Sager
Sorry @AdamMesser1, I was not clear. There was a recent update to ArcGIS Online. I would advise creating a brand new API Key and trying the workflow again. If this is still not working, I would recommend reaching out to Technical Support (if you have access) or your Account manager.
