Adding Features to layer error
1460
01-17-2019 06:27 AM
OisinSlevin
I keep running into this issue when trying to add polygons to my feature layer,
My code basically pulls down a feature from a layer,
modifies some of the text fields
then attempts to upload the feature to a different feature layer
The same code works fine for line and point geometry data
I also strip out any fields that are auto populated ex GlobalID and OBJECTID so this unique identifier is not something I feed in.
an_object={
"geometry":object.SHAPE,
"attributes":attributes
add_result=some_layers[6].edit_features(adds=[an_object])
{'addResults': [{'objectId': None, 'uniqueId': None, 'globalId': '09846522-E815-405F-98C5-22991AA70D59', 'success': False, 'error': {'code': 1000, 'description': 'Conversion failed when converting from a character string to uniqueidentifier.'}}], 'updateResults': [], 'deleteResults': []}
Tags (1)
OisinSlevin
Found the issue, The features layer had user attributes which were "esriFieldTypeGUID" and if you leave them null, but leave them in the "attributes" while adding them , then it throws this error.
OisinSlevin
