Accessing AGOL Notebook Logs with ArcGIS API for Python
2283
04-27-2023 11:59 AM
DanielMarkbreiter
Background
I have an ArcGIS Notebook hosted on ArcGIS Online. I can see all of my scheduled Tasks using the AGOL website as well as their "Task details" (see attached screenshot). I'd like to retrieve this information (specifically when a Task was "Created" and its "Status") via the ArcGIS API for Python.
Troubleshooting
Looking at the ArcGIS API for Python documentation it appears that there is the `arcgis.gis.tasks` module that will list all Tasks with the TaskManager.search() object method. However, the documentation states that this operation is for "Enterprise configuration 10.8.1+".
Question
Is there a similar operation for ArcGIS Online users? Being able to access that information programmatically would be extremely beneficial for the development of Notebooks that require logs.
esptjones
I ran into this today and figured I would answer this post since it has been awhile and no one has answered it. I don't have a perfect solution using the ArcGIS python API, however, you can view tasks and their runs in AGOL by just making a GET request. I will provide an image and a the code I used to get it below.
2024-08-21 15_42_47-scratch.ipynb - Customers - Visual Studio Code.png2024-08-21 15_42_47-scratch.ipynb - Customers - Visual Studio Code.png
 Here is the code I used if you are interested. It was hastily written so don't judge too much 😊
import requests
from arcgis.gis import GIS
from datetime import datetime
import json
def extract_tasks(response😞
    tasks = response.json()['tasks']
    task_list = []
    for task in tasks:
        next_run = task.get('nextStart')
        if next_run:
            next_run = datetime.fromtimestamp(next_run / 1000).strftime('%Y-%m-%d %H:%M:%S')
        task_list.append(
                'task_id': task.get('id'),
                'task_name': task.get('title'),
                'schedule': task.get('cronSchedule'),
                'next_run':next_run,
                'task_state': task.get('taskState'),
                'active': task.get('active')
    return task_list
def extract_task_runs(response😞
    runs = response.json()['runs']
    results = []
    for run in runs:
        t = run['task']
        result = json.loads(run['result'])
        start_time = result.get('startTime')
        end_time = result.get('endTime')
        if start_time:
            start_time = datetime.fromtimestamp(int(start_time) / 1000)
        if end_time:
            end_time = datetime.fromtimestamp(int(end_time) / 1000)
        if start_time and end_time:
            duration = end_time - start_time
        else:
            duration = None
        results.append(
                'task_id':t.get('id'),
                'task_name': t.get('title'),
                'run_id': run.get('runId'),
                'status': run.get('status'),
                'start_time': start_time.strftime('%Y-%m-%d %H:%M:%S'),
                'end_time': end_time.strftime('%Y-%m-%d %H:%M:%S'),
                'duration': duration,
                'results': result
    results[0]
    return results
# Get the GIS Object
gis = GIS(settings['agol'], settings['username'], settings['password'])
# Extract Token for requests
token = gis._con.token
# Get the username and url key
user = gis._username
url_key = gis.properties.urlKey
# Get a list of all tasks from the organization
tasks_url = f"https://{url_key}.maps.arcgis.com/sharing/rest/community/users/{user}/tasks?f=json&token={token}"
response = requests.get(tasks_url)
if response.status_code != 200:
    raise Exception(f"Failed to get tasks. Status code: {response.status_code}")
task_list = extract_tasks(response)
print(task_list[0])
# Get the runs for the first task
task_id = task_list[0]['task_id']
url = f"https://{url_key}.maps.arcgis.com/sharing/rest/community/users/{user}/tasks/{task_id}/runs?f=json&token={token}"
response = requests.get(url)
    raise Exception(f"Failed to get task runs. Status code: {response.status_code}")
task_runs = extract_task_runs(response)
# Print the first run for demonstration
task_runs[0]
