NOTE: ArcGIS API for Python ideas require a label. See the descriptions to choose the label that best aligns with your idea submission.
| Open | My organization is attempting to create an automated process using the API for Python to check items in our organizat... by ColinBergmann_ct Occasional Contributor 5 0 | 5 | 0 | |
| Open | When cloning webmaps from one portal to another, it is possible to provide a lookup dictionary with {source_item_id :... by MarcelBeckmann Frequent Contributor 2 0 | 2 | 0 | |
| Open | Adding an image to a StoryMap Briefing using the GUI automatically fits the image to the size of the Block. After add... by ATFerguson Regular Contributor 0 0 | 0 | 0 | |
| Open | Hi,Please adjust the item_id parameter of the arcgis.gis.server.Server.publish_sd function to support a dictionary of... by PatriceLabbé Frequent Contributor 2 0 | 2 | 0 | |
| Open | Currently, if you read the configuration JSON for a web map (specifically looking at each layer within it's operation... by MikeLachance1 Regular Contributor 3 0 | 3 | 0 | |
| Open | Please update the API to enable adding all Layers and Tables at once.As of the ArcGIS API for Python version 2.4.0 an... by Clubdebambos 0 0 | 0 | 0 | |
| Open | When exporting data to a particular format, provide methods that enable users to check what potential limitations may... by PeterKnoop 1 2 | 1 | 2 | |
| Open | Initially, when I copy featurelayer on AGOL,I encountered an error, as described in this link.To resolve the issue, I... by MasaakiKurokawa Occasional Contributor 0 0 | 0 | 0 | |
| Open | Request:Enhance the arcgis.features.FeatureLayer.append() and arcgis.features.Table.append() functions in ArcGIS API ... by DanaAbumourhMAG Emerging Contributor 5 1 | 5 | 1 | |
| Open | Extend the capabilities of the swap_view method in the ArcGIS API for Python to include swapping the source of views ... by RobertHolliday Regular Contributor 16 1 | 16 | 1 | |
| Open | Many vector tile services published to ArcGIS Enterprise can submit a cache rebuild job through the item's options. T... by DavidSolari 0 0 | 0 | 0 | |
| Open | At the moment there is no property in the RecycleItem properties property that states the date/time the item was dele... by Clubdebambos 2 0 | 2 | 0 | |
| Open | Hey All,An issue I recently encountered brought up this idea, the ArcGIS API for Python has the ability to send out e... by CodyPatterson 4 1 | 4 | 1 | |
| Open | You can manually group and ungroup layers in a webmap. This functionality is required with the ArcGIS API for Python.... by Clubdebambos 3 1 | 3 | 1 | |
| Open | Currently, when using query_domain() on a hosted feature layer you are returned and empty list (which is an improveme... by Clubdebambos 1 0 | 1 | 0 |
Idea Submission Guidelines
