ArcGIS API for Python 1.2.1 released
1470
08-28-2017 02:32 PM
by Anonymous User
Not applicable
1 4 1,470
We are excited to announce the v1.2.1 of the ArcGIS API for Python which includes a number of bug fixes and updated documentation for a lot of the new features introduced earlier in v1.2. You can find the list of reported bugs addressed in the release notes. This release includes documentation for building a distributed GIS using collaborationsmanaging your ArcGIS servers using Python APIadministering your ArcGIS Org / Enterprisecustomizing the appearance of your Org.
Please upgrade your package using the command in your Anaconda shell or terminal:
conda upgrade -c esri arcgis‍‍
If this is the first time you’re installing the Python API, use the following command:
conda install -c esri arcgis‍‍
If you installed using ArcGIS Pro, you can also update your package by using the 'Update Packages' tab from the 'Python' tab in Pro backstage.
Thank you,
ArcGIS API for Python team.
4 Comments
DanPatterson_Retired
You should also upgrade Spyder to at least 3.2.1 to fix the clear screen in the IPython window... makes working with ArcGIS API a lot cleaner since prior versions just scrolled past content in the window, rather than cleaning it out from view.
PhilLarkin1
Version 1.2.2 is advertised as the latest version, but 1.2.3 is reported in conda.
arcgis version 1.2.3
by Anonymous User
Not applicable
https://community.esri.com/groups/arcgis-python-api?sr=search&searchId=967ae281-fc7c-4698-8dc0-18629...‌ we quickly released two subsequent versions with minor bug fixes. Please get the latest v1.2.3 of the conda package.
PhilLarkin1
Thanks for your prompt reply AMani-esristaff
