I am using this sample here: http://www.w3schools.com/bootstrap/bootstrap_modal.asp to attempt to create a bootstrap dialog box. The only problem is I can't get the dojo grid to display inside of my modal dialog box. What am I doing wrong?
Here is my code with references as to where I am trying to display the modal and the grid.
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.14/dojox/grid/resources/Grid.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.14/dojox/grid/resources/claroGrid.css">
<link rel="stylesheet" href="http://maxcdn.bootstrapcdn.com/bootstrap/3.3.5/css/bootstrap.min.css">
<script src="https://ajax.googleapis.com/ajax/libs/jquery/1.11.3/jquery.min.js"></script>
<script src="http://maxcdn.bootstrapcdn.com/bootstrap/3.3.5/js/bootstrap.min.js"></script>
<title></title>
<style>
#myModal {
height:80%;
</style>
<!-- HTML5 shim and Respond.js IE8 support of HTML5 elements and media queries -->
<!--[if lt IE 9]>
<script src="//cdnjs.cloudflare.com/ajax/libs/html5shiv/3.7/html5shiv.min.js"></script>
<script src="//cdnjs.cloudflare.com/ajax/libs/respond.js/1.4.2/respond.min.js"></script>
<![endif]-->
<script type="text/javascript">
var dojoConfig = {
parseOnLoad: true,
isDebug: true,
locale: 'en-us',
extraLocale: ['ja-jp']
</script>
<!-- This will not work if you set the html lang https://community.esri.com/thread/81475 -->
<script src="http://js.arcgis.com/3.14/"></script>
<style>
.modal-body, #grid
height:500px;
</style>
</head>
<body class="claro">
<label id="lblOwnerAddress" for="ownerAddress">Owner's Address</label>
<input type="text" id="ownerAddress" name="ownerAddress" value="111 S Main" />
<div class="container">
<!-- Modal -->
<div class="modal fade" id="myModal" role="dialog">
<div class="modal-dialog">
<!-- Modal content-->
<div class="modal-content">
<div class="modal-header">
<button type="button" class="close" data-dismiss="modal">×</button>
<h4 class="modal-title">Modal Header</h4>
</div>
<div class="modal-body">
<table data-dojo-type="dojox/grid/DataGrid" data-dojo-id="grid" id="grid" data-dojo-props="rowsPerPage:'5', rowSelector:'20px'">
<thead>
<tr>
<th field="address" width="200px">Address</th>
<!--<th field="score">Scrore</th>-->
</tr>
</thead>
</table>
</div>
<div class="modal-footer">
<button type="button" class="btn btn-default" data-dismiss="modal">Close</button>
</div>
</div>
</div>
</div>
</div>
<script>
var items;
require([
"dojo/on",
"dojo/_base/array",
"esri/tasks/locator",
"dojox/grid/DataGrid",
"dojo/data/ItemFileReadStore",
"dijit/registry", "dojo/parser",
"dijit/layout/ContentPane",
"dojo/domReady!"
function (on, arrayUtils, Locator, DataGrid, ItemFileReadStore, registry, parser) {
parser.parse();
document.getElementById("grid").style.display = "none";
on(document.getElementById('ownerAddress'), 'focusout', checkAddress);
function checkAddress() {
var locator = new Locator("http://maps.decaturil.gov/arcgis/rest/services/Public/WebAddressLocator/GeocodeServer");
//console.log(document.getElementById('ownerAddress').value);
var node = document.getElementById('ownerAddress');
// according to your service it takes Single Line
var params = {
"Single Line Input": node.value
locator.addressToLocations(params).then(function (addressCandidates) {
//console.log('success', addressCandidates);
//console.log(addressCandidates.length);
if (addressCandidates.length > 1) {
for (a = 0; a < addressCandidates.length; a++) {
// This is the address that should go into a grid cell
console.log(addressCandidates.address);
console.log(addressCandidates);
items = arrayUtils.map(addressCandidates, function (result) {
console.log(result);
return result;
console.log(items);
var data = {
items: items
console.log("Log" + data);
store = new ItemFileReadStore({
data: data
// display grid
document.getElementById("grid").style.display = "block";
// Show modal
$("#myModal").modal("show");
var grid = registry.byId("grid");
grid.setStore(store);
//registry.byId("grid").display=block;
grid.on("rowclick", onRowClickHandler);
var adresses = addressCandidates.map(function {
return x.address;
//console.log(adresses);
}).otherwise(function (err) {
console.log('somethings wrong', err);
function onRowClickHandler(evt) {
console.log(evt);
var clickedAddress = evt.grid.getItem(evt.rowIndex).address;
console.log(clickedAddress);
alert(clickedAddress);
// console.log(evt.explicitOriginalTarget.data);
</script>
</body>
</html>
