I have web maps created in Portal for ArcGIS and are shared within the organization. I am trying to bring those maps into my app using ArcGIS API for JavaScript. When I use the unique web map id, the map does not show up. However, if I use the map id of a map created in ArcGIS Online, the map shows up.
require([ "esri/views/MapView", "esri/WebMap", "dojo/on", "dojo/domReady!" ], function( MapView, WebMap, on ) { var webmapids = [ "f2777e16f8734dc19321558bde5b26ba", "71ba2a96c368452bb73d54eadbd59faa", "45ded9b3e0e145139cc433b503a8f5ab" ]; /************************************************************ * Create multiple WebMap instances ************************************************************/ var webmaps = webmapids.map(function(webmapid) { return new WebMap({ portalItem: { id: webmapid } }); });
you have to specify a portal URL, via thearcgisUrlproperty, Besides the default ArcGIS Online URL ofhttp://www.arcgis.com/sharing/rest/content/items.
arcgisUtils.arcgisUrl = "http://mydomain/sharing/rest/content/items";
Thank you so much Karsten.
