use ArcGIS Dynamic Service in beta
4619
08-03-2015 01:49 AM
selvarajkrishnan1
I want to use ArcGIS REST Service as a ArcGISDynamicService in 4.0 beta. Any one tried this in 4.0 beta version.?
Tags (1)
DavideLimosani
It works, also if ArcGISDynamicLayer class is not documented yet.
Try this:
require([
  "esri/Map",
  "esri/views/SceneView",
  "esri/layers/ArcGISDynamicLayer",
  "dojo/domReady!"
], function (Map, SceneView, ArcGISDynamicLayer) {
  //Create map
  map = new Map({
    basemap: "hybrid"
  //Create SceneView
  view = new SceneView({
    map: map,
    container: "viewDiv",
    camera: {
      position: [7.654, 45.919, 5183],
      tilt: 80
  map.add(new ArcGISDynamicLayer("http://.../MapServer") );
I was not able to use indetify instead, it seems that the IdentifyParameters class is not already supported.
Davide
DavideLimosani
Try this:
require([
  "esri/Map",
  "dojo/domReady!"
  //Create map
  map = new Map({
    basemap: "hybrid"
  //Create SceneView
    map: map,
    camera: {
      tilt: 80
Davide
selvarajkrishnan1
Thank you David, It is working fine, Also I want to know whether we can use digit.toolbar in this version?
DavideLimosani
You are welcome.
digit.toolbar is dojo, not esri api, so i think you should not have problems using it.
Davide
RolandMartin
It looks as though this only currently works in 3D mode, not 2D - is that correct?
Thanks!
selvarajkrishnan1
Yes Roland Martin, I tried many ways in 2D. It is not working. Hope this will work in only 3D..
