urlUtils JS 4.2
2102
01-24-2017 03:03 PM
PatrckWild
I see that JS API 4.2 doesn't yet support urlUtils.
Is this awaiting or is there a new/better solution?
Does anyone have an example to build a simple app with JS 4.2 that will accept url parameters like the 3.19 exp_history example?
https://developers.arcgis.com/javascript/3/samples/exp_history/?parceled=1919402007
PW
ReneRubalcava
Are you looking for urlUtils.urlToObject()?
urlUtils | API Reference | ArcGIS API for JavaScript 4.2
urlUtils.urlToObject("https://developers.arcgis.com/javascript/3/samples/exp_history/?parceled=191940200");
/** outputs
  "path": "https://developers.arcgis.com/javascript/3/samples/exp_history/",
  "query": {
    "parceled": "1919402007"
SteveCole
You could still do this with strictly javascript. I mean, it's certainly more elegant and nice to have a helper like the urlUtils but isn't that hard to do otherwise. Here's a snippit that zooms the map to a lat/long if passed as a parameter in the URL:
//If a coordinate location was passed as a parameter, zoom the map to it
//Evaluate the URL of this HTML page to determine if any parameters were passed with it
htmlPagePath = window.location.toString();
qLocation = htmlPagePath.indexOf('?');
if (qLocation < 1){
    passedLatLong = false;
} else {
    passedLatLong = true;
if (passedLatLong)
 //Extract the lat/long coordinates passed as a parameter with the URL
 var coordStr = window.location.toString().substr(qLocation + 1,window.location.toString().length);
 var coords = new Array();
 coords = coordStr.split(',');
 //Create a lat/long point
 var bridgeLoc = new Point(coords[0],coords[1], new SpatialReference({wkid:4326}));
 var theLatLongPoint = new Point(coords[0],coords[1], new SpatialReference({ wkid: 4326 }));
 var webMercatorPoint = webMercatorUtils.geographicToWebMercator(theLatLongPoint);
 map.centerAndZoom(webMercatorPoint, 16);
 map.resize();
This just assumed that the url was something like "http://server/folder/index.html?-122,48"
You can easily adjust this to be "...?parcelId=xxxx"
ReneRubalcava
/** outputs
  "query": {
PatrckWild
Looks like it moved from esri/urlUtils to esri/core/urlUtils
Thanks Rene!
