Hello,
I want to have edit functionality to the attributes in webscene but i am unable to do so ,i tried applyEdit method from arcgis api also 3d editor widget but its not working, kindly please check where i am getting wrong,i had published 3d layer from arcgis pro software and below i am sharing the scene layer associated with feature layer as well as portal id of webscene, Thank you in advance
SceneLayer:
https://globolive3d.gl3d.in/agserver/rest/services/Hosted/Anupam_Land_Use/SceneServer
FeatureLayer
https://globolive3d.gl3d.in/agserver/rest/services/Hosted/Anupam_Land_Use/FeatureServer
webscene portal ID: 8482745e9d164eb5afb30a2f6cd883b5
Below is my code for 3d editor
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8" />
<meta
name="viewport"
content="initial-scale=1,maximum-scale=1,user-scalable=no"
<title>
Edit features in 3D with the Editor widget | Sample | ArcGIS API for
JavaScript 4.17
</title>
<link
rel="stylesheet"
href="https://js.arcgis.com/4.17/esri/themes/light/main.css"
<script src="https://js.arcgis.com/4.17/"></script>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
.esri-editor .esri-item-list__scroller {
max-height: 350px;
#setting {
padding: 10px;
</style>
<script>
require([
"esri/layers/FeatureLayer",
"esri/WebScene",
"esri/views/SceneView",
"esri/widgets/Editor"
], function (FeatureLayer, WebScene, SceneView, Editor) {
// Create a map from the referenced webscene item id
let webscene = new WebScene({
portalItem: {
var view = new SceneView({
container: "viewDiv",
qualityProfile: "high",
map: webscene
view.when(function () {
view.popup.autoOpenEnabled = false; //disable popups
// Create the Editor
var editor = new Editor({
view: view
// Add widget to top-right of the view
view.ui.add(editor, "top-right");
const satelliteCheckbox = document.getElementById("satellite");
// change event handler to set the basempa accordingly
satelliteCheckbox.addEventListener("change", function (event) {
view.map.basemap = event.target.checked ? "satellite" : "";
// Add the checkbox to the bottom-right of the view
view.ui.add("setting", "bottom-right");
</script>
</head>
<body>
<div id="viewDiv"></div>
<div id="editorDiv"></div>
<div id="setting" class="esri-widget">
<input type="checkbox" id="satellite" /><label for="satellite"
>Show satellite basemap</label
><br />
</div>
</body>
</html>
Hello,
Your feature layer is not editable that is why the editor widget is not displaying anything:
If you have a look at the following sample:
the feature layer "Recreation" is configured as editable:
https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/EditableFeatures3D/FeatureServer/1
At the very bottom you can see "add features", "update features" and "delete features" operations which is not the case on your feature layer.
Hope that help
