setBasemap() not working on webmap with string or object value
8222
13
07-11-2013 08:06 AM
deleted-user-RAnWn8DDSd1P
http://www.portlandmaps.com/arcmaps/setBasemap.html
You can see in console both map objects reflect the change of basemap in _basemap and _layers has the new layer, but neither the string value 'topo' or an object of type esri/utils/Basemap work as a param to setBasemap() to successfully swap it out. what am i missing here?
JonathanUihlein
It works for a split second when I add:
var mapDeferred = new esriUtils.createMap('ec7080edfb7c4197989dee3c6207264c', 'map1', {
 mapOptions:{
  basemap:"streets"
However, the 'streets' basemap gets covered near instantly by another layer.
From my point of view, it looks like a specific layer in your webmap is completely covering the basemap.
only layers on in the webmap are the basemap and a second tile layer for labeling. they continue covering after setBasemap().
[ATTACH=CONFIG]25879[/ATTACH]
JonathanUihlein
Not sure how much this helps, but I got the basemap to change by using the following code:
var baseMapLayer = new ArcGISTiledMapServiceLayer("http://services.portlandmaps.com/ags/rest/services/Public/Basemap_Gray/MapServer");
map1.addLayer(baseMapLayer);
I added the above two lines after "var map1 = response.map;"
You'll also need to change your require statement.
require(["esri/layers/ArcGISTiledMapServiceLayer", ... ], function(ArcGISTiledMapServiceLayer, ... ){ ... });
API Ref: https://developers.arcgis.com/en/javascript/jsapi/arcgistiledmapservicelayer-amd.html
yeah i know i could manually add and toggle ArcGISTiledMapServiceLayer's with visibility to change basemaps, but setBasemap() is supposed to handle this, and does correctly for non-webmap map objects.   I added the non-webmap cases to my example to show them working for non-webmap.
JonathanUihlein
Hey Aaron, I may have found a temporary solution.
I created a copy of your webmap and made some changes.
I was able to successfully change the basemap via code with the following steps:
1) Change the 'Basemap Color' layer of your webmap to 100% transparent in the webmap interface
2) Use
 map1.setBasemap('topo');
This fixed the problem.
The basemap you were using in the webmap didn't seem to be implemented correctly so you can either change the 'Basemap Color' layer to 100% transparent or remove that layer completely.
For some reason,the basemap you are using in your current webmap is being treated like a standard layer and not an actual basemap ( I have no idea why ).
My code (using the edited webmap):
[HTML]<!DOCTYPE html>
<html>
    <head>
        <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
        <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9">
        <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
        <title>Basemap Test</title>
        <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dojo/dijit/themes/claro/claro.css" />
<link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/esri/css/esri.css" type="text/css"/>
<script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/"></script>
<script type="text/javascript">
require(['esri/arcgis/utils',
  'esri/dijit/BasemapLayer',
  'esri/dijit/Basemap',
  'dojo/ready',
  'esri/layers/ArcGISTiledMapServiceLayer'
function(esriUtils,esriBasemapLayer,esriBasemap,ready, ArcGISTiledMapServiceLayer){
  var webmapID = '2e3365c4e32d45138fa5c3c115eaf66b';
  ready(function(){
   var mapDeferred = new esriUtils.createMap(webmapID,'map1');
   mapDeferred.then(function(response){
    //var baseMapLayer = new ArcGISTiledMapServiceLayer("http://services.portlandmaps.com/ags/rest/services/Public/Basemap_Gray/MapServer");
    // map1.addLayer(baseMapLayer);
   var mapDeferred2 = new esriUtils.createMap(webmapID,'map2');
   mapDeferred2.then(function(response){
    var map2 = response.map;
    var grayB = new ArcGISTiledMapServiceLayer( 'http://services.portlandmaps.com/ags/rest/services/Public/Basemap_Gray/MapServer');
    var grayBase = new esriBasemap({
     layers: [grayB],
     title: 'Gray Basemap',
     thumbnailUrl: 'http://services.portlandmaps.com/ags/rest/services/Public/Basemap_Gray/MapServer/info/thumbnail'
     //map2.addLayer(grayBase);
     map2.setBasemap(grayBase);
  });//end ready
</script>
</head>
<body class="claro">
  <div id="map1"></div>
  <div id="map2"></div>
</body>
</html>
[/HTML]
This is what my site looks like:
[ATTACH=CONFIG]25892[/ATTACH]
do you mean there's an improper transparency setting on the service?  where in /arcgis/manager/ would i change that?
http://services.portlandmaps.com/ags/rest/services/Public/Basemap_Color/MapServer
JonathanUihlein
I wish I could provide an answer to that question but to be honest I have no idea. I'm mainly a JS guy.
How I edited the webmap:
1) Went to
http://jsapi.maps.arcgis.com/home/webmap/viewer.html?webmap=ec7080edfb7c4197989dee3c6207264c
(or rather, made a duplicate of your webmap, but the above is yours)
2) Clicked Content Tab
3) Click the 'down-arrow' next to 'Basemap Color'
4) Selected Transparency - changed to 100% transparent
Pic of steps:
[ATTACH=CONFIG]25893[/ATTACH]
*NOTE
You need to use setBasemap(); in code after loading the webmap because otherwise a basemap will not show at all.
Hopefully you find the answers you seek; I wish I could be more helpful!
if i set the basemap in the webmap to 100% transparent then my webmap would not have a basemap shown by default.  I want to rely on the default basemap being in the webmap, as a webmap structure has a basemap layer.  no matter what's in a webmap, the documentation tells me there's a setBasemap() method that seeks to do exactly that.  I'm not interested in workarounds.  I need a confirmation that this is either a bug because, for some reason, with this particular type of webmap or its contents, the method does not perform as advertised, or if the basemap service or webmap has been set up wrong such that it causes the method to falter.
JonathanUihlein
I think your webmap is set up incorrectly so I am unable to offer any further advice.
I would love to know why this doesn't work if someone else can jump in and provide some answers 🙂
Remember to mark useful posts and to mark the thread as 'answered' when someone provides a legitimate answer.
