Set zoomToFullExtent to be my Initial Extent
2373
8
01-23-2012 08:08 AM
CarrieTropasso1
I am using the Navigation Toolbar from the API Samples.  However, the Zoom to Full Extent zooms to the full extent of the underlying base map and I want this to zoom to my Initial Extent.  I saw a previous post on here that states to save a copy of the extent and connect a button or link to a function that passes your extent to map.setExtent ().
I already have the button (from the Navigation Toolbar api sample) and the function for this right now is ???onClick:function(){navToolbar.zoomToFullExtent();}??? which works as described above (zooms to the extent of the base map).
I am fairly new to JavaScript but can usually get things to work if I have examples.  That being said, can someone provide me a code example showing me how to do this rather than just outlining the steps?
Carrie
derekswingley1
You can take a look at the code for zoomToFullExtent by typing this in firebug or chrome dev tools console:
navToolbar.zoomToFullExtent.toString()
That will print:
"function () {
  var map = this.map;
  map.setExtent(map.getLayer(map.layerIds[0]).initialExtent);
The easiest way to change this is to re-define zoomToFullExtent for your toolbar. After you create your toolbar, do something like this:
navToolar.zoomToFullExtent = function() {
  var map = this.map;
  map.setExtent(appFullExtent);
Where appFullExtent is a global that represents your app's full extent.
CarrieTropasso1
Thanks! That's what I needed and I got it working successfully.
derekswingley1
Thanks for following up. Can you mark my post as an answer?
BillShockley
Thanks...it took me a little bit, but I got mine to work as well!!
JessicaKnight1
Thanks for this. Worked like a charm!
danbecker
awesome. Thanks Derek!
RobinAlexis_Olaya
That will print:
"function () {
  var map = this.map;
  var map = this.map;
Thank's it's very usefull.
Muchas gracias, me ayudó bastante. From Cali, Colombia
RobertKirkwood
That will print:
"function () {
  var map = this.map;
  var map = this.map;
where do i modify the code with the above edit?
here is what i have:
 navToolbar = new Navigation(map);
    on(navToolbar, "onExtentHistoryChange", extentHistoryChangeHandler);
    registry.byId("zoomin").on("click", function(){
        navToolbar.activate(Navigation.ZOOM_IN);
    registry.byId("zoomout").on("click", function(){
        navToolbar.activate(Navigation.ZOOM_OUT);
    registry.byId("zoomfullext").on("click", function(){
    registry.byId("zoomprev").on("click", function(){
        navToolbar.zoomToPrevExtent();
    registry.byId("zoomnext").on("click", function(){
        navToolbar.zoomToNextExtent();
    registry.byId("pan").on("click", function(){
        navToolbar.activate(Navigation.PAN);
    registry.byId("deactivate").on("click", function(){
        navToolbar.deactivate();
    function extentHistoryChangeHandler(){
        registry.byId("zoomprev").disabled = navToolbar.isFirstExtent();
        registry.byId("zoomnext").disabled = navToolbar.isLastExtent();
Thanks in advance!
