Removing duplicates from an array
1979
11-03-2014 08:37 PM
joepublic
Robert, et al
On further testing (click on the 3rd button "city models") I see that there are duplicates in my object ids which are being used to create the countries layer.  This causing my application to run slow.  A look at the console.log of the featureCollection on line 300 rquery.run(function(error, featureCollection, response) will show what I mean
Is there a way to remove the duplicates (so there is only one objectid per country) before the layer is added to my map?
Spec attached
KenBuja
MVP Esteemed Contributor
There are a couple of ways to do this, like this or this
joepublic
Thanks for the suggestions Ken.
But my question is for a specific case.
The problem is here: rquery.objectIds();... This creates an
array of opjectIds with dupes.
I am trying to remove the dupes before I pass the array to :
countries = L.geoJson(featureCollection).addTo(map);
ReneRubalcava
Esri Frequent Contributor
The above examples could be tweaked a little for that.
var unique = {};
var distinctFeatures = featuresCollection.features.filter(function(feature) {
  var oid = feature.properties.OBJECTID;
  if (!unique[oid]) {
    unique[oid] = oid;
    return true;
  return false;
featureCollection.features = distinctFeatures;
That's a quick and dirty way of doing it based on the example Ken provided.
joepublic
Thanks Rene!!
I work with this and let you know if I still problems
Chris
