Hello again,
I have issue: I have mapView and I use elevation profile widget on it, it works perfect, shows elevation data as shoudl, but after it I can't use Popup, I click on map, but nothing happens. What might be cause?
thanks,
I'm wondering if this is a bug. I get the same results when adding the widget to the PopupTemplate sample.
<html> <head> <meta charset="utf-8" /> <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" /> <title>Intro to PopupTemplate | Sample | ArcGIS API for JavaScript 4.19</title> <style> html, body, #viewDiv { padding: 0; margin: 0; height: 100%; width: 100%; } </style> <link rel="stylesheet" href="https://js.arcgis.com/4.19/esri/themes/light/main.css" /> <script src="https://js.arcgis.com/4.19/"></script> <script> require([ "esri/Map", "esri/layers/FeatureLayer", "esri/views/MapView", "esri/widgets/Legend", "esri/widgets/ElevationProfile" ], (Map, FeatureLayer, MapView, Legend, ElevationProfile) => { // Create the map const map = new Map({ basemap: "gray-vector", ground: 'world-elevation' }); // Create the MapView const view = new MapView({ container: "viewDiv", map: map, center: [-73.95, 40.702], zoom: 10 }); view.ui.add(new Legend({ view: view }), "bottom-left"); /************************************************************* * The PopupTemplate content is the text that appears inside the * popup. {fieldName} can be used to reference the value of an * attribute of the selected feature. HTML elements can be used * to provide structure and styles within the content. The * fieldInfos property is an array of objects (each object representing * a field) that is use to format number fields and customize field * aliases in the popup and legend. **************************************************************/ const template = { // autocasts as new PopupTemplate() title: "{NAME} in {COUNTY}", content: [ { // It is also possible to set the fieldInfos outside of the content // directly in the popupTemplate. If no fieldInfos is specifically set // in the content, it defaults to whatever may be set within the popupTemplate. type: "fields", fieldInfos: [ { fieldName: "B12001_calc_pctMarriedE", label: "Married %" }, { fieldName: "B12001_calc_numMarriedE", label: "People Married", format: { digitSeparator: true, places: 0 } }, { fieldName: "B12001_calc_numNeverE", label: "People that Never Married", format: { digitSeparator: true, places: 0 } }, { fieldName: "B12001_calc_numDivorcedE", label: "People Divorced", format: { digitSeparator: true, places: 0 } } ] } ] }; // Reference the popupTemplate instance in the // popupTemplate property of FeatureLayer const featureLayer = new FeatureLayer({ url: "https://services.arcgis.com/P3ePLMYs2RVChkJx/ArcGIS/rest/services/ACS_Marital_Status_Boundaries/FeatureServer/2", popupTemplate: template }); map.add(featureLayer); const elevationProfile = new ElevationProfile({ view: view, profiles: [ { type: "ground" // first profile line samples the ground elevation }, { type: "view" // second profile samples the view and shows building profiles } ], // hide the select button // this button can be displayed when there are polylines in the // scene to select and display the elevation profile for visibleElements: { //selectButton: false } }); // add the widget to the view view.ui.add(elevationProfile, "top-right"); }); </script> </head> <body> <div id="viewDiv"></div> </body> </html>
Are you seeing any error messages in your console? Can you either post your code or put together a code sample that reproduces the error?
Hi Ken,
I update working file here, you can simply check, I see errors only from imported libraries (it no problem, u can ignore and type error, this u can ignore too, it is old errors 😄 ). I really do not understand what is problem, i out widget at top and at the end too of the code, but get same result 😞
Wow....4300 lines of code is way too much for me to wade through. Can you distill this down to a short example that replicates your problem?
Sorry for this , i did not notice...
Here is code only with basic widgets and Elevation Profile Widget, also one FL with popupTemplate and Custom Symbol...
I noticed that, before making Elevation profile, popup works, but after i make Profile by clicking on map and it creates graphic line on map (like elevation path), after this i can not call popup 😕
Here is a working file,
Yes, i think same ,
So what we do know? Let ESRI knw that it is a bug?
Yes, open a case with Esri to verify that it is a bug.
