mixin w/o a base case
532
08-27-2010 10:00 AM
HaroldBostic
Occasional Contributor II
Prior to dojo v1.4 you could do:
dojo.declare("A",[null,B],{someFuncs});
after v1.4 you get error declare: mixin #0 is null
what is an exceptable pattern to mixin a class when you don't have a base class to inherit from?
Thanks
derekswingley1
If I understand you correctly, you should just pass in null. Check out the docs for dojo.declare:  http://docs.dojocampus.org/dojo/declare
HaroldBostic
can you provide an example.  Prior to v1.4 I could pass in null, but that no longer works.  hopefully I'm missing something simple
