lang.clone === error? when copying esri graphic
4690
01-15-2015 12:05 PM
JerryGarcia
Occasional Contributor II
I get the following error when trying to clone a grahic:
Uncaught TypeError: Cannot read property 'path' of null
If I cannot use Dojo lang.clone to copy a graphic, then can someone provide some sample code to do this?
I need to make a copy of a graphic, change it's name attribute, and add it to a FeatureLayer.
Thanks!
KenBuja
What is your code for cloning the graphic? This example seems to work properly, which slightly modifies the "Add graphics to a map" sample.
var graphic = new Graphic(evt.geometry, symbol);
var clone = lang.clone(graphic);
map.graphics.add(clone);
JerryGarcia
I get the error with this code:
var g = this.polylineGraphics.graphics[0];
var clone = lang.clone(g);
where as polylineGraphics:
        this.polylineGraphics = new FeatureLayer({
            layerDefinition: {
                geometryType: 'esriGeometrypolyline',
                fields: [{
                    type: 'esriFieldTypeOID',
                    alias: 'OBJECTID',
                    domain: null,
                    editable: false,
                    nullable: false
                    type: 'esriFieldTypeString',
                    alias: 'name',
                    domain: null,
                    editable: true,
                    nullable: false
            featureSet: null
            title: 'polylineGraphics',
            mode: FeatureLayer.MODE_SNAPSHOT
JohnGrayson
I wonder if this will work:
var clonedGraphic = new Graphic(sourceGraphic.toJson()):
SrihariManepalli
This worked for me. Thanks.
